You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Here are the three recalls for the 08 Expeditions. The mushy brake problems do have a fix (I think). See below.
Make : FORD Model : EXPEDITIONYear : 2008
Manufacturer : CONTINENTAL AUTOMOTIVE SYSTEMSMfr's Report Date : DEC
04, 2007
NHTSA CAMPAIGN ID Number : 07E105000 N/A
NHTSA Action Number: N/A
Component: SERVICE BRAKES, AIR:ANTILOCK:CONTROL UNIT/MODULE
Potential Number Of Units Affected : 10481
Summary:
CERTAIN CONTINENTAL AUTOMOTIVE ABS AND ESC CONTROL MODULES SOLD FOR
INSTALLATION ON THE VEHICLES LISTED ABOVE. SOME OF THE HYDRAULIC
VALVES IN THE ESC MODULE WERE BUILT WITH EXTRA CHECK BALLS.
Consequence:
THE EXTRA CHECK BALLS CAN RESTRICT THE FLOW OF BRAKE FLUID THROUGH
THE VALVE AND CAUSE REDUCTION OF BRAKE FORCE.
Remedy:
EACH VEHICLE MANUFACTURER WILL FILE A DEFECT REPORT AND REMEDY PLAN
FOR THEIR VEHICLES WHICH INCLUDED THESE MODULES AS ORIGINAL
EQUIPMENT. VEHICLES WILL BE REPAIRED AT NO COST TO THE OWNER. OWNERS
CAN CONTACT EITHER THEIR VEHICLE MANUFACTURER OR CONTINENTAL
AUTOMOTIVE AT 248-393-5300 FOR FURTHER INFORMATION.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY
ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY:
1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Manufacturer : FORD MOTOR COMPANYMfr's Report Date : NOV 14, 2007
NHTSA CAMPAIGN ID Number : 07V541000 N/A
Component: AIR BAGS:FRONTALRIVER SIDE INFLATOR MODULE
Potential Number Of Units Affected : 45
Summary:
CERTAIN VEHICLES FAIL TO CONFORM TO THE REQUIREMENTS SPECIFIED IN
FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 208, 'OCCUPANT CRASH
PROTECTION.' THE DRIVER AIR BAG MODULE MAY NOT HAVE BEEN PROPERLY
ASSEMBLED.
Consequence:
THIS CONDITION MAY PREVENT THE DRIVER AIR BAG FROM PROPERLY
DEPLOYING AND REDUCE OCCUPANT PROTECTION IN THE EVENT OF A CRASH.
Remedy:
DEALERS WILL REPLACE YOUR DRIVER AIR BAG MODULE FREE OF CHARGE. THE
RECALL BEGAN ON NOVEMBER 20, 2007. OWNERS MAY CONTACT FORD AT
1-800-392-3673.
Notes:
FORD RECALL NO. 07C19. CUSTOMERS MAY ALSO CONTACT THE NATIONAL
HIGHWAY TRAFFIC SAFETY ADMINISTRATIONŋS VEHICLE SAFETY HOTLINE AT
1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Manufacturer : FORD MOTOR COMPANYMfr's Report Date : FEB 04, 2008
NHTSA CAMPAIGN ID Number : 08V058000 N/A
Component: LATCHES/LOCKS/LINKAGESOORS:LATCH
Potential Number Of Units Affected : 123632
Summary:
FORD IS RECALLING 123,632 MY 2007-2008 EXPEDITION AND LINCOLN
NAVIGATOR VEHICLES. THE DOOR HANDLE HOUSING EMBOSSMENT RETAINING THE
BOTTOM OF THE INTERIOR DOOR HANDLE SPRING ON ALL SIDE DOORS MAY
FRACTURE DURING NORMAL CUSTOMER USAGE. THIS CAN RESULT IN
INSUFFICIENT SPRING FORCE TO RETURN THE HANDLE TO THE FULLY CLOSED
POSITION. THE HANDLE MAY BE LOOSE CAUSING A RATTLE OR NOISE AND THE
HANDLE MAY NOT RETURN TO THE FULLY CLOSED POSITION. THIS CONDITION
MAY ALSO PROVIDE A DELAYED RESISTANCE WHEN ACTUATING THE HANDLE
PRIOR TO OPENING THE DOOR.
Consequence:
IN THE EVENT OF A SIDE IMPACT CRASH, THE INTERIOR DOOR HANDLE MAY
CAUSE THE DOOR LATCH TO OPEN INCREASING THE RISK OF INJURY TO A
VEHICLE OCCUPANT.
Remedy:
DEALERS WILL REPLACE THE INTERIOR HANDLE SPRING ON ALL SIDE DOORS.
THE RECALL IS EXPECTED TO BEGIN DURING FEBRUARY 2008. OWNERS MAY
CONTACT FORD AT 1-800-392-3673.
Notes:
FORD RECALL NO. 08S03. CUSTOMERS MAY ALSO CONTACT THE NATIONAL
I have a 2008 limited & checked the VIN vs. a dealer and called Ford and had no open recalls on my particular truck. Depends heavily on your mfg date.. i don't recommend calling Ford - they told me 10 times i could do it on the website by entering your VIN.. but i wanted a voice. After the 9th or so time she told me, i figured it might be accurate online also.
I hope mine goes as fast as yours did. I need to get the oil change done soon. I just got my case of Royal Purple off EBay so I should be good to go this week.
__________________
White Sand 08 Expy EL Limited 4x4 with everything but the power running boards & trip tunes.
I will call to make sure all is well before I show. I have done it the other way and gotten quite the suprise. I will see how long it takes them for mine and report back.
__________________
Well, I got the oil changed BUT no springs. Their system showed they had them but none to be found. The guy before me had the same issue we both got oil changes and tire rotations on the house though. I am now waiting for my call that they are in.
__________________
