Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-21-2008, 03:48 PM
krol's Avatar
krol is starting off with a positive reputation.
1992 460 won't run on propane - questions
I have a 1992 F250 460 running on both gas and propane. Last week after I switched from gas to propane the engine backfired (what I was told was called a lean-burn) and then stopped running on propane. I have had it back fire before, but it always keeps running. Any ideas? It runs fine on gas but when I switch to propane it will die right away. I have a full propane tank.
Thanks for the input.
__________________
1992 F250 460 5 speed
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-21-2008, 03:54 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
Regulator?
__________________
Bear 45/70
Gimp Racing
  #3 (permalink)
Old 02-25-2008, 04:11 PM
Thunderjet4x4 is starting off with a positive reputation.
Check the intake plumbing, had an 89 460 efi/lpg did the same, sounded like someone fired a rifle under the hood, it blew apart a plastic piece on the intake, so of course it stalled, having a 3" hole in the intake hose. Fired up fine on gas of course, albeit no filtration till I got it home. Made a plastic plug, epoxied it together and worked fine since. If the intakes are similar, seems to me the long dual rubber hoses would have too much lpg buildup in them. Ideally, if you could mount the mixer closer to the throttle plate it would be way better. Hope this helps!
  #4 (permalink)
Old 03-20-2008, 04:03 PM
dutchlincoln79 is starting off with a positive reputation.
how's your propane setup? wich mixer, wich stuff, brand, pics maybe?
thank you.
  #5 (permalink)
Old 04-01-2008, 01:56 AM
No pics, sorry. It was an impco 425 mixer, with an adapter to fit on the rubber hoses where the factory airbox was, then had just a paper element filter. Truck was sold years ago, although it did work pretty good.
  #6 (permalink)
Old 04-01-2008, 11:04 AM
so, you just fitted a 425 in front of the MAF/Speed density?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
