Replacing Dash Lights - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 02-21-2008, 08:35 AM
standinby standinby is offline
standinby is starting off with a positive reputation.
Hello all,
I haven't crawled under the dash yet, but the light in my 02 gear selector has gone out. I suspect a burned out bulb. Is there anything I need to know before I get under there? Is going in from the bottom even the correct way or do I have to remove the dash? Just a little advance help would be appreciated. Thank you, Mike.
Old 02-21-2008, 11:36 AM
caseys's Avatar
caseys caseys is offline
caseys has a good reputation on FTE.caseys has a good reputation on FTE.
I know we do not have the same Ford...but, on my 96 Explorer I recently replaced the burned out bulbs in the dash and had to remove the dash instrument cluster to do so. I had found instructions on this website on how to do it. At first glance in looked like a nightmare but in reality it really was not bad. Took me about 45 minutes ... maybe less, and that is because I was going slow and taking time out for a beer.
I did follow other folks suggestions in replacing all the bulbs and using the long life bulb types since I had the dash apart. Murphy's Law would suggest that if you replace just the one bulb and second one will go out just after you put everything back together.
Old 02-22-2008, 05:24 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman NewEnglandHerdsman is offline
Moderatee...
NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.
Quote:
Originally Posted by standinby
Hello all,
This is the same light as the odometer lamp? if so, and it's the same as my 2003, there's no crawling under the dash. There's a couple of trim screws in the bezel above the dash cluster - unscrew them then the bezel comes out after you pry the bottom - there's a spring clip arrangement there. One of those things that feels like you're going to break it getting it out. Then the cluster itself comes out with four more screws. That lamp is a #74, I believe...
Old 02-22-2008, 06:38 PM
Thanks all. I think we'll give a go this weekend. I'll let you know.
Old 02-29-2008, 09:05 AM
I undertook that job last Saturday and it went well, thanks to all your help. It was a little daunting but turned out to be pretty simple. And I did replace all the bulbs while it was out, so I didn't have to go thru that again soon.. Thanks again all.
cant figure out why dash lights have gone out!!!!! 91 f250 Robert Hummer Electrical Systems/Wiring 1 09-27-2014 06:56 AM
Dash acting up Aetic 1994.5 - 1997 7.3L Power Stroke Diesel 0 05-29-2014 09:23 PM
Dash Lights bvieages 6.0L Power Stroke Diesel 5 11-06-2013 03:20 PM
1971 ford truck dash lights beckman 1967 - 1972 F-100 & Larger F-Series Trucks 10 11-18-2012 03:25 PM
reverse light wire under dash? mbettez79 1999 to 2016 Super Duty 2 09-12-2008 12:15 PM
Tags
2005, bulb, bulbs, cluster, dash, escape, f250, ford, instrument, lights, mariner, mazda, mercury, panel, remove, replace, replacing, size, tribute
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
