Cuts out when hot - Ford Truck Enthusiasts Forums
Cuts out when hot
Old 09-09-2002, 10:54 AM
moose4130 moose4130 is offline
moose4130 is starting off with a positive reputation.
Post Cuts out when hot
In my '79 F-150 with a 351m, I have a problem with the engine stalling when it gets hot. It will die, and I am stuck for about 45 minutes until it cools off enough to start again. Any suggestions?
Old 09-09-2002, 03:45 PM
breathinhappily breathinhappily is offline
breathinhappily is starting off with a positive reputation.
Cuts out when hot
I had the same problem in my 79 with a 400. My problem was that when I'd stop my truck I couldnt start it untill it cooled. One of those times I happen to have some water and I poured it on the ignition control box b/c It nearly burnt my hand when I touched it. After I cooled it off the truck fired right up. I bought on from AutoZone but eventually ran into the same problem...I bought my next one from Checker an its working great....I kept the old one as a spare...The symptom for my truck was that when I tried to start nothing would happen...
Hopefully this helps...
John
Old 09-09-2002, 05:21 PM
garypettengill's Avatar
garypettengill garypettengill is offline
garypettengill is gaining momentum as a positive member of FTE.
Cuts out when hot
Been there before too. Go get a new ingition module from the auto parts store. Keep the old one in case of emergency. If your're junk yarding, keep an eye out for a spare. Just makt sure it has the same color gromet for compatability.
Gary
Old 09-10-2002, 12:36 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Cuts out when hot
If you want a GOOD module find a Ford Motorcraft OEM module. Many parts stores have testing machines for igntion modules. When you mount your module use spacers to hold it 1/4" off the mounting surface. This will allow cooling air to get to the bottom of the module. Cary the parts store module as a spare. I run an OEM module now and I haven't had to change it for years. The parts store modules would run a year at best.
Old 09-24-2002, 01:18 PM
rocky rocky is offline
rocky is starting off with a positive reputation.
Cuts out when hot
I had a similar problem, but it turned out not to be the module. I had a pinhole in the fuel line, back by the tank. I guess it was letting air in, and with the engine warm it was "vapor-locking" somehow. I had to manually shake the fuel line from beginning to end, until my grand-daughter saw the wet spot. Until then, I had changed modules, coils, etc, and as the engine had cooled off, it seemed fine. That is, until it got warm again. Just one more thing to check out.
Old 09-24-2002, 04:06 PM
Torque1st's Avatar
Posting Legend
Cuts out when hot
WOW! That took some work to find!
:-staun
Thanks for the info.
Old 09-24-2002, 05:57 PM
christop43's Avatar
christop43 christop43 is offline
christop43 is starting off with a positive reputation.
Cuts out when hot
How to check ATF level? Saxon 1999 to 2016 Super Duty 12 07-09-2012 05:38 PM
you know it's hot when... tjc transport General NON-Automotive Conversation 18 08-03-2006 11:45 PM
When is the tranny too hot?? walt1968 1994.5 - 1997 7.3L Power Stroke Diesel 10 07-10-2006 05:25 PM
blows hot air when its hot outside! big_saxy Cooling, Heating, Ventilation & A/C 1 08-06-2005 10:55 PM
A/C problem on 03 Expy scott7512 Expedition & Navigator 0 06-14-2005 03:18 PM
Tags
cuts, ford, hot, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
