Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-20-2008, 08:31 PM
70T351W is starting off with a positive reputation.
Wrong Cam?
Sometime ago I bought a 351w cam from a guy with no specs. He said it was a mild RV cam (new). I know it is not a 302 cam. I had a machine shop look it over, they said it appeared to be slightly above a stock cam. Anyway I put it in my 351w I was building. The short block is all stock, Heads have new valves and guides with roller rockers. Edlebrock intake with edlebrock 600 cmf carb. Replaced the points with pertronix ingnition system. I am not trying to build a hot rod just a motor that runs good.
The problem I am having is this; If I were to go and crank on it, it would not start right up. When it does start it does only by continually cranking. It sounds great when it gets going. I have checked and set the timing, checked for vac leaks. I am at the point where I am thinking it could either be the cam or distributor.
Here are two questions;
1, not knowing the year application-Did ford keep the same timing degree on all there small block camshafts (maybe it could be a timing issue with the cam?)
2, Is there a dwell in the distributor that needs to be set or would it matter with the pertronix.
It never back fires or pops out the carb or exhaust. Any thoughts or help would be appreciated.
__________________
Kill em and Grill em
96 F350 Flatbed
A bad day fishing is better than a good day at work!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-21-2008, 03:03 AM
Broken40's Avatar
Broken40 is starting off with a positive reputation.
I know that if you have a 302 block and a 351w cam you have to set the timing to the cam itself for it to run right.
__________________
4wd 73 F-100 390 FE, 7" lift
WARN hubs 4 bbl Eddies Carb
2wd 79 F-100 351W, C-4 tranny. 4 bbl Eddies carb
"What doesn't kill ya only makes you stronger"
  #3 (permalink)
Old 02-21-2008, 10:34 AM
Mike G is starting off with a positive reputation.
Most Ford timing is around teh 8 degree mark, if I recall correctly. Does the motor fire back up right away after it has been running? There is no dwell with the Pertronix, but if I recall correctly there was a feeler guage provided to set the pick-ups apart with. Also, did you widen the gap on the plugs after installing the Pertronix. How is the shot of fuel from the carb?
Just a few thoughts... --Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
  #4 (permalink)
Old 02-21-2008, 11:11 AM
Much thanks Mike;
I have played with the timing back and forth. Yes after it has been running it does fire right back up. I used the feeler guage to set the pick-ups. I did not widen the gaps on the plugs though. It seems to be getting a good shot of fuel. I must also mention that when I step on it from a stop it has a large flat spot. I have to raise my foot up for it to regain life. It doesnt pop or back fire though.
__________________
96 F350 Flatbed
  #5 (permalink)
Old 02-21-2008, 06:00 PM
Quote:
Originally Posted by 70T351W
Yes after it has been running it does fire right back up...
.. I must also mention that when I step on it from a stop it has a large flat spot. I have to raise my foot up for it to regain life.
It sounds like you are experiencing carb problems, I know the Edel is not a fovorite around here... Do you have a manual or electric choke on there? Widen up the gap on your plugs per the Pertronix recommendations and get the carb tuned out/dialed in.
--Mike
__________________
Mike G
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
  #6 (permalink)
Old 02-21-2008, 08:37 PM
I will do some playing around with the carb. I recently came across a guy who did not have good things to say about the edlebrock carbs. If I can get ahold of an extra carb (just to see if it acts as it should) I will put it on. When I adjust the choke it acts as if it is going to start.
__________________
96 F350 Flatbed
  #7 (permalink)
Old 02-22-2008, 05:58 PM
Broken40's Avatar
to tell you the truth, there is nothing wrong with edelbrock carbs, its the people who don't know how to adjust them who hate them. I have 2 of them and have had zero problems with em. if you need help with adjusting it let us know we'll help you.
__________________
  #8 (permalink)
Old 02-22-2008, 06:59 PM
kaboom10's Avatar
kaboom10 is starting off with a positive reputation.
Quote:
I loved my Edelbrock carb. They tell you so much about tuning and it fit my V6 manifold unlike a holley.
__________________
2002 F-150 5.4L 4wd
Amsoil filter element w/ mod air box
Baer rotors EGR Carbon Kevlar pads
Flowmaster
Kenwood
Optima battery
Livewire PRP tuned w/wideband O2
Modified 4R70 Trans(shift kit)
4.88 gears and Trutrac carrier
B.F.Goodrich Rugged Trail
Stab the throttle ain't got no bottle
  #9 (permalink)
Old 02-22-2008, 09:14 PM
thunderbirdreg is starting off with a positive reputation.
302 ho &351 windsor firing order is 13726548. Non ho 302 firing order is 15426378 and the order is all in the cam . Try the non ho firing order
  #10 (permalink)
Old 02-22-2008, 11:33 PM
doug1222556's Avatar
doug1222556 is starting off with a positive reputation.
Here's a thought- have you checked you fuel pump for pressure and delivery? Could be starving for gas untill it sucks enough to run. Just a thought.
  #11 (permalink)
Old 02-23-2008, 12:45 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy is starting off with a positive reputation.
I kinda thought the samething, but it should fire right up though with the gas from the bowl.
I also have an edelbrock and love it (as long as you get the right set of springs for the secondaries they are great (no leaks) Holleys are just fine to, but I always have problems with em leaking, so I do have a lot more experience with em b/c I've had to rebuild a lot more of em, never have rebuilt a edelbrock, but when I bought the carb. new it came with a book on how to properly tune it, very good and informational, I read the whole thing just b/c I was curious as to how they worked. Sadly I lost the book.
Trying the reg 302 firing order does sound like a good start though, I would think it would pop though if that many cyl. were off or if you wired ur dist clockwise accidently (my pickup did run, but not well), at least to eliminate it, next I'd throw a different carb. on that was on another car so you know it's close to being tuned and doesn't have some problem of it's own. You said it's getting good fuel, any black smoke when it flattens out?
Another thought, you put a cam in, you didn't accidently get off a tooth on the chain did you?
__________________
Redneck-Cowboy
86 F-150 4x4, 4spd w/ a 300, Headers, 500 cfm 4-barrel, D.U.I or "H.E.I" ignition/dist., mild cam with chevy rockers, steel timing gears, decked the block and head .015, bored .060, true dual straight 2.5" all the way back ( a little to snappy, but frickin LOUD)
  #12 (permalink)
Old 02-25-2008, 07:20 PM
Hi We have not heard from you how did you make out with the cam problem? I am curious
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
