Programmer/chip and air intake recommendations
Hello All! New to the boards. I have an 07 5.4 F150 S-Crew 4x4. I am looking to do some mods like a programmer/chip and air intake. What is the best stuff out there that works for these trucks? what programmer will give me the most bang for the buck? Which air intakes do you like best? There are so many options out there it is hard to determine what is the best or better than the rest. Any info is greatly appreciated.
I am also looking at doing a 2.5 leveling kit. Does the ride change much doing this? Are new shocks needed or will spacers work just fine? I don't want to compensate the ride quality.
Thanks again!
Thanks again!
I installed a Truxxx 3" leveling kit on my 06, everything fitted perfectly, also had a 4 wheel alignment done. Using Hypertech Max Energy Programmer which makes a difference. K&N Air Charger would be the way to go, I tried cheaper ones but it would set an error code after 30 miles of driving, and no comparison with the HP gains.
IMHO,
stay away from "canned" tunes and K&N, a sock filters more dirt..
use "bama chips" or "dp-tuner" for a programmer, these companies do custom tunes so you can tell them how you want the trans to act, what modifications have been done, and what octane you want to use, it costs slightly more but your truck is really tuned!
S&B makes a good intake, the owner has spent alot of money testing the filters filtering ability not just flow. Airade makes a replacement intake tube, you would keep the stock filter housing but change the intake tube to one with no baffles and a larger I.D., plus its much cheaper than a complete intake kit.
Originally Posted by rdalley
I had the Superchips Flashpaq and didnt really like it. I just got an Edge Evolution yesterday and immediately installed it on the #2 setting. I can tell you it really woke up my truck. What a difference. This is an otherwise stock 5.4 Screw.
http://motorhaven.autoanything.com/performance-chips/61A2389A0A0.aspx
brickwahlracing
22
09-27-2007 12:22 PM
