Greasing Your (trailer) Balls?
Greasing Your (trailer) *****?
Hahaha! Get your mind out of the gutter, I'm talking bout trailer hich *****. I have been towing a small trailer for a while now and resently put a dab of grease up there to lube the locking mechanisim Now seems better to tow? any comments? Should that be done?
It won't cause any problems with the hitch coming off. That's just a little silly. I would be more worried about what it does to the trailer that have the lights grounded through the ball. It might screw that up a little. I've never greased any of mine. Still have not had an issue with any.
I had a ball get a large gouge chewed in it on a cross-country trip, so lube is a good thing. I am sure to keep the hitch on my truck and trailer well lubed now. You can tell when the hitch is dry, the truck will move a lot more in response to the trailer's movement.
And if lubing your hitch can cause it to come loose, then we should see a lot more large trucks loose their trailers, since the fifth wheel has to be greased.
I dont ever worry about the coupling on the trailer, but when I do tow I always put a dab of grease on the ball. I have only heard from one person on a fishing trip that you werent supposed to do it, and happened to be in Wallys with the same person a day or so later and I pointed out in the automotive section that there is actually grease just for it, and is labeled "Ball Lube", never heard anything else. I started doing it after watching my dad, who is a truck driver, do it when he pulled his boat, he figured it was the same principal as lubing the fifth wheel on his tractor.
