Vent window glass seal
Old 02-21-2008, 05:17 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
I didn't read your question right...Sorry about that.
Old 02-21-2008, 07:52 PM
P3aflyer's Avatar
P3aflyer
P3aflyer is offline
Bucks ford ,, No problem my friend.. I did ask for any and all coments.. so this thread is on me.. I wish it weren't now. but what the H--L!!
This thread seems to be getting kind of clogged up?? So, to speak, I may have to start a new one so folks don't get board and leave before the get the meat of it.. so far only one person has come close to answering this question..
It appears that there are not that many people that change out the glass on their vent windows??
Old 02-22-2008, 01:10 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The vent glass to vent frame is held with "glass tape," as is the main window held to the metal window channel. It's not necessary to remove either glass from the vent frame or window metal channel in order to install the weatherstrips.
Old 02-22-2008, 02:03 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is offline
Smile
WOW how did this thread get so misguided? all we want to know is where to get the correct glass tape from.
I guess im just going to take my wing and glass to the glass shop.
I hope i dont sound rude
Old 02-22-2008, 02:07 AM
NumberDummy
Any auto glass shop will have it.
Old 02-22-2008, 06:39 PM
P3aflyer's Avatar
P3aflyer
P3aflyer is offline
TAAA DAAAA!!!!
Thank you. I was thinking on signing up for a few classes at the college to figure out auto shop repair... then I though about just taking an English class.. I may just not know how to ask the right question... I'll blame it on the beer.????
Thank you Number dummy and everyone else..
Final score??? Glass tape!
Old 08-03-2014, 09:12 AM
lens54's Avatar
lens54
lens54 is offline
Hey Bill i found your old post here as I was searching on installing glass tape on my 54 F100 vent window. I found the glass tape at Blue Oval Truck PN WE-0075. A roll about an inch wide and rubberized on one side....felt sort on the other side.
My question is does the RUBBER side go against the glass or the felt (non rubber) side?
And on the felt side (whether against the glass or in the channel) does that side require adhesive?
Thanks Len
Old 08-03-2014, 09:30 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Thanks Len
Actually, that's not what you want. If you're setting glass into the frame, you want glass setting tape. P/N WE-0075 looks to be a "universal" type weatherstripping, not setting tape.
Here's a link to Bob Drake's page. There are a lot of suppliers for it though. Just enter "glass setting tape" into Google and a bunch of suppliers will pop up.
https://www.bobdrake.com/Categories7...a-ba49123304a0
Old 08-03-2014, 09:37 AM
lens54's Avatar
lens54
lens54 is offline
Oh crap thanks for telling me that Mike. I will order the glass setting tape. It looks like it is rubber on both sides. That said do i need to glue it into the channel and or to the glass?
Appreciate your reply.
Len
Old 08-03-2014, 09:41 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's a link to answer your question.
Eventually I'll have to do the same thing. I've got all the stuff, just haven't gotten to that point yet.
window setting tape. Adhesive? [Archive] - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Yeah, I know it's a Chevy site but the answer is "universal".
Old 08-03-2014, 10:03 AM
lens54's Avatar
lens54
lens54 is offline
Mike i have some good 3M double sided tape that i ordered a while back. Pretty sure it is the same as what you are talking about.
Etiher way, when setting into metal track since both sides will be sticky. What stick it to the glass they use dish soap or something to push it into track?
Old 08-03-2014, 11:25 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I haven't installed my glass yet but I've read in a couple of forum reply's that they used WD-40.
  #28
Old 08-16-2014, 07:00 PM
lens54's Avatar
lens54
lens54 is offline
Glass Setting Tape for Vent Window
Hey Mike I wanted to follow up with you on that vent window. I ordered the correct Glass Setting Tape. I found it on ebay pretty easily. Anyway after banging my stubborn head against the wall trying to make what I had on hand work, I ended pulling it all off, cleaning up the glass and channel and starting all over again.
This time I used the CORRECT Glass Setting Tape like you suggested. For my 3/64" for my 54 F100. It is CRITICAL that you get exactly the right thickness for your track or it will not hold. There is a formula for figuring that out if you need it.
Anyway the tape (not really tape at all not glue sticky but very tacky) was gummy tacky like on both sides, about 1.5" wide and I got a 20' roll for about $11. Here is the ebay item # 151375721189 .
I cut a piece to length, wrapped around edge of glass leaving extra on both ends. I used clothes pins to hold it place. On the corner you will have to cut little V's of course to make the curve.
Then took my wifes hair dryer on hot for a minute or so. Heating it up just enough to make it soft and mold it to the glass. Pulled the clothes pins about 5 minutes later and she stayed in place.
Slid in the track to test if I needed dish soap I did not. It slid it with some good solid force but went all the way in. Right away I tried to pull it out a little to make sure it was not too loose...naaa she is there to stay. I figure leave the vent window closed for a week or so to let it all seat in and dry up and in place.
Anyway wanted to share that with you and anyone else replacing a vent window. Your glass setting tape set me on the right path. The other stuff I got before with cloth on one side and rubber on the other was totally wrong like you said. The key, was to get the right stuff and the right thickness. After that it was smooth sailing.
Thanks for your response it helped me figure it all out.
Len
54 F100
  #29
Old 08-16-2014, 07:47 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks for taking the time to update.
It's nice to know that things work out okay.
  #30
Old 08-17-2014, 10:08 AM
fitzmotor's Avatar
fitzmotor
fitzmotor is offline
The stuff you want is the butyl tape that is designed for that, NPD has it for cheap,($12.00 for 4') fold it over the glass and press it down so it sticks to the glass, cut a pie slice out at the tight corner and form it back together (this stuff is very workable you can cut it and work it back together) I sprayed glass cleaner to help it slide in, then get a soft mallet or rubber dead blow hammer and put the frame on the edge of a block of wood so you dont damage the hinge and hammer the glass in, it takes a lot of force to seat the glass, then just trim off the excess thats hanging out of the frame.
My glass buddy suggested not using polyurethane, if you ever needed to change the glass you would have to throw the frame away as getting the old urethane out would be tough.
jvmcc
03-10-2016 07:39 PM
ssg1957
07-02-2015 06:40 PM
dagwood387
16
07-01-2015 08:23 AM
Truckmano5
27
02-01-2013 02:32 AM
ungerp
01-02-2013 03:54 PM
Quick Reply: Vent window glass seal
