1976 F350 dually
Old 02-20-2008, 01:25 PM
bmutterb's Avatar
bmutterb
bmutterb is offline
1976 F350 dually
I have a chance to get a 1976 F350 at an auction. Is there anything specifically I should look for. Thanks
Old 02-20-2008, 02:39 PM
dakonthemountain's Avatar
dakonthemountain
dakonthemountain is offline
Since they didn't make a factory F350 dually in 76 (unless is was a flatbed, I think) I would look for the quality of the conversion. Others here will have better specifics to look for..
Good luck on the auction!
Dak
Old 02-20-2008, 06:13 PM
bmutterb's Avatar
bmutterb
bmutterb is offline
Yes......it is flatbed. Thanks
Old 02-20-2008, 06:30 PM
masterbeavis's Avatar
masterbeavis
masterbeavis is offline
Does the front take DRW rims, or SRW?
Old 02-20-2008, 08:07 PM
bmutterb's Avatar
bmutterb
bmutterb is offline
The truck was used on a farm and looks like they are just regular 8 bolt steel wheels. I really don't know the difference between DRW and SRW.
Old 02-20-2008, 10:24 PM
masterbeavis
DRW=dual rear wheels, SRW=single rear wheels
Old 02-21-2008, 02:32 AM
4starcstms's Avatar
4starcstms
4starcstms is offline
The front wheels.. Do they come out like this:
Orrr... are they like regular rims??
The point of the above post, if it has Regular Rims, like the 2nd picture, then its been converted and isnt a factory truck.
Old 02-21-2008, 02:14 PM
bmutterb's Avatar
bmutterb
bmutterb is offline
Its like the first picture (not as fancy) and definitely factory type. The rear is dual wheels. On the inside door panel it has Canadian Trailmobile Corporation, so guess they did the conversion for FORD. I saw the truck this morning and it will need a little work...a few small holes above rocker panels, emergency brake stuck and owner says clutch is not good. I started it and put it in gear but need to raise clutch to very top to engage, so it works but not the way it should. The brakes, wipers, exhaust, lights, horn, window regulators, defroster, guages all seem to work. Its a manual transmission with a 351. I can't tell too much about the suspension but frame looks OK with only a bit of surface rust. Will this truck be money pit or are repairs easy to do?
Old 02-24-2008, 02:19 AM
rusty7983's Avatar
rusty7983
rusty7983 is offline
make sure the brakes are good. there is alot of money( mine was just parts) that could be invested if its worn down. i redid mine all the way, drums, rotors , hydraulics friction bearings and seals. lots of money.
Old 02-24-2008, 03:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Dak
It wouldn't necessarily be a flatbed...F350 dually's were sold as a cab and chassis only. It was up to the buyer to add behind the cab equipment.
For example all the 1973/79 F350 dually's U-Haul owned, had a box on the back. Other bodies could be stake beds, utility beds, dump beds, etc.
There were no factory F350 Styleside pickups with dual rear wheels till 1980.
Turdle
10-23-2022 09:43 AM
hazer
05-30-2013 11:19 PM
cowgirlup11
04-03-2011 12:35 PM
jowilker
06-03-2000 11:48 AM
rob albright
06-09-1999 05:39 AM
Quick Reply: 1976 F350 dually
