Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 03-12-2008, 09:17 PM
rob_nc is gaining momentum as a positive member of FTE.
Quote:
He said the company had a strategic choice to make: "We could exit. We could partner. We could acquire."
This is an interesting comment by the Cat exec.,particularly the last part. Who is left to acquire? All 4 heavy truck OEMs are/will be vertically integrated by 2010.
Sponsored Links
To remove this ad, register today!
  #32 (permalink)
Old 03-12-2008, 10:08 PM
origcharger is gaining momentum as a positive member of FTE.
Quote:
Considering medium trucks, if Ford and International are totally parting ways, isn't the production of F650-F750s in question?
__________________
Powerstroking Seven T444Es, one VT365 and one 6.0. Also four DT466s, one DT360 and a Mercedes MBE906.
I'm doing my part to reduce food imports, control rising food costs and help feed the children, my trucks run on 100% petroleum diesel. What are you doing?
  #33 (permalink)
Old 03-12-2008, 10:31 PM
Louisville Joe is starting off with a positive reputation.
Quote:
Yes it is. Back in November, International notified Ford that they will end the joint venture that builds the 650, 750, and LCF ('Blue Diamond') in September 2009. There has been no word on what Ford will do if this happens.
  #34 (permalink)
Old 03-13-2008, 03:14 AM
immastrokinnow's Avatar
immastrokinnow is starting off with a positive reputation.
most cat engines use lower rpm. you would need about a 10 speed eaton to make it hit useful speeds. most people would not buy it because of constant gear hunting. i would buy one just for the emblems. way too many changes would have to be done around the entire truck. and as for the dt466. the new ones are crap. complete crap and nothing but crap.....
__________________
1997 psd x-cab long bed 4x4
tymar intake
3in dp FINALLY IN
bullydog 4 bank 6 pos. chip (crap)
6in bull haulers
missing cat and muffler
fpr shim
14.7k mod
coons tranny mod
TEMP USED TRANS
meyer snow plow
AWAITING INSTALL
gauges (egt, boost, trans temp)
just got stage 1 injectors
dp-tuner
dan
  #35 (permalink)
Old 03-13-2008, 07:59 AM
Quote:
If this were true, then Cummins, Detroit, and Volvo would be in trouble also. All modern big-bore diesels use this same philosophy, gear fast/run slow. Eaton's 10 spd is the most popular transmission on the road today.
  #36 (permalink)
Old 03-13-2008, 08:21 AM
yea in rigs. but your avg. 3/4 and 1 ton truck buyers arnt going to want to shift trough all those gears. i would love it though...
__________________
tymar intake
3in dp FINALLY IN
6in bull haulers
fpr shim
14.7k mod
coons tranny mod
TEMP USED TRANS
meyer snow plow
AWAITING INSTALL
dp-tuner
dan
  #37 (permalink)
Old 03-13-2008, 09:59 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy is starting off with a positive reputation.
Well the only DT466's (plus 414's, and 436's) I see or mess with are from the 70/80's, I didn't even know they made new ones.
__________________
Redneck-Cowboy
86 F-150 4x4, 4spd w/ a 300, Headers, 500 cfm 4-barrel, D.U.I or "H.E.I" ignition/dist., mild cam with chevy rockers, steel timing gears, decked the block and head .015, bored .060, true dual straight 2.5" all the way back ( a little to snappy, but frickin LOUD)
  #38 (permalink)
Old 03-13-2008, 10:31 AM
"and as for the dt466. the new ones are crap. complete crap and nothing but crap....."
Ok, I give, whats wrong with the new ones?
We have a 2004, 2006 and a 2007, outside of some variable pitch turbo issues they seem to be ok.
__________________
  #39 (permalink)
Old 03-13-2008, 11:26 AM
Most P/U buyers are buying auto transmissions anyway. A slower running 6.4 would improve fuel economy but the power curve needs to match.
  #40 (permalink)
Old 03-13-2008, 01:31 PM
ag30265's Avatar
God,Family,Guns & Trucks
ag30265 is gaining momentum as a positive member of FTE.
I'll take a newer dt466 or 530 over any other power platform currently available right now!
The cummins is giving constant shop time and electronics trouble, the isuzu/gm duracrap is almost worked out but the fuel milage is horrendous, the cat c-7 is a turd for power and speed no matter how you drive it or gear it and the fuel mileage is no better then the duramax, The mbe light engine can't keep the fuel and the coolant out of the oil pan long enough to get a money return on the better fuel mileage it offers, so that leaves you with the dt's and the UD's......I'll take the dt's due to the trucks- In a cabover your the first thing to the accident when one happens!!!
I'll keep with international and their occasional injector failure and turbo problems, and after a half hour on the laptop....outrun every other truck on the road and still get decent fuel mileage.
The real question is when will volvo step into the medium duty market and give the public a great med duty work horse with a great power plant!?!?
__________________
"Always mystify, mislead, and surprise the enemy...repeated victory will make you invincible. Have faith in God that the victory will be won, irregardless of odds." --- Gen. T. J. Jackson
Club SNL- #13
'87 Bronco(daily driver)
'91 F-150(ole faithfull)
'78 F-150 4X (F. O. Resto)
'76 F-150(parts)
'77 F-150(wifes ride)
  #41 (permalink)
Old 03-18-2008, 07:45 PM
Farmall05's Avatar
Farmall05 is starting off with a positive reputation.
you guy were talking about a dt 466 in a pick up it has been done. A local guy did it in a 96 f350 it wins the truck pulls at the county fair every year
__________________
Farmall05
94 f250
7.3 5 speed
2 wd
  #42 (permalink)
Old 03-24-2008, 12:17 AM
nitrogen is starting off with a positive reputation.
i'm not sure why anyone would ever want a 3306 i ran them in several different semis they were underpowered sucked up just as much fuel as the bigger more powerful 3406. I talked with 1 fleet owner who had run the3306 in motorgraders and loved it, so they put them into their trucks when they got the option he said that was about the worst mistake him and his bros. ever made they just didn't stand up at all
__________________
2005 F350 Lariat crew 4x4
traded F350 XLT supercab 4x4 what a stinker
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
