97 Expedition Subwoofer Replacement
Does anyone have a recommendation on replacing a blown rear subwoofer in my 97 ford Expedition? I went to a car stereo place and they said it was a dealer specific item. I called the dealer and they said it was discontinued. I saw some posts from years ago but those items were discontinued. the sounds system in the vehicle is the stock EB Mach sound system.
I am also having trouble removing the blown speaker. I have the panael off and all the screws removed but I am unable to pull it out. Can anyone give me the 411 on this.
Thanks,
John
Thanks,
John
Originally Posted by jsavlen
Thanks i'll look into it. I am thinking that did not fit into the standard opening but you connected it right up to the existing wiring?
http://www.crutchfield.com/App/Produ...3&tp=113&avf=N
Well, that link didn't work....try these.
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=530&i=236FEN1T45&c=3&tp=113&avf=N
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=530&i=13690942&c=3&tp=113&avf=N
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=530&i=236FEN1AT4&c=3&tp=113&avf=N
That MTX sub costs $239 from Hi-Fi Sound Connection.
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1354723/vpcsid/0/SFV/30046
Fish
Fish
Fish
Fish
Depending on where you are, most custom audio shops can do some amazing things in that space (I am an Installer for Tweeter). We used to carry MTX and from my experience they are very poor for what they cost, you'd be better spending your money getting a custom box made.
Also if you just want to replace the woofer itself, you can steal it out of an Exploder as they use the same woofer. Also a JL 10w0 4ohm will work ok as they are very power sensitive and your factory amp does not put out much.
I agree with bandvan, I am also an installer have been for quite a few years, the JL 10w0 is a great sub especially for the $. If you have a dremmel or a small die grinder with a cutting bit (1/8 drill bit or roto zip bit) just trim the inside of the hole for the woofer. I have a 2001 Lincoln Nav with a blown factory sub and the amp was bad. Might wanna check the amp out or see if the woofer is for sure bad by taking a 12/14v cordless drill battery and try poping the speaker. Just for record my 97 explorer has 4 JL13w0s and it is not right Also RE is a good sub, a little more pricy but works well in a small enclosure
shagnwagn
16
02-18-2017 09:04 AM
rickrackleyjr
1997-2006 Expedition & Navigator
07-04-2016 09:02 PM
scflowmaster
04-16-2009 11:11 AM
jfaaborg
04-08-2005 12:24 PM
