Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-20-2008, 10:02 AM
fballer985 is starting off with a positive reputation.
straight pipe with or without cat
i have a 1995 f150 with a 302 and am undecided if i want to run with or with out a cat when doing a straight pipe and size also, im between 2.25 and 2.5. suggestions would b helpful
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-20-2008, 03:55 PM
95FordF150's Avatar
95FordF150 is starting off with a positive reputation.
I cut my exhaust just ahead of the cat and ran that for a few weeks. The sound was obnoxiously loud. I added about 3' of 3" pipe dumped in front of the rear axle and that just made the sound worse. I also lost some low end power. I added an 3" glasspack (spiraled louvered inside) and that made the sound a lot better and gained a little more low end and works great for highways speeds.
I would recommend opening up your air intake since your exhaust will be more free flowing. I found one on ebay for $25 and could definately tell a difference compared to the stock box.
As I have a 302 too, I suggest cutting the cat and going 2.5" single out, or 2.25" dual out exhaust. The 3" is nice and all but I think a little smaller would give better performance. My plan right now is too reduce from 3" to 2.5" and dual out 2.25" with Flowmaster Super 40's.
Depends on what you're looking for since everybody's preference for sound/perfomance is different.
Good Luck!
__________________
"think for yourself, question authority"[/right][/font]
  #3 (permalink)
Old 02-21-2008, 09:40 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
It is illegal to run without a cat, and you or others could get carbon monoxide poisoning. I say run the cat, it can help take the rasp and pop out of the sound. Just go with a good high flow cat.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #4 (permalink)
Old 02-22-2008, 10:37 AM
96_fordF150 is starting off with a positive reputation.
Question
Good Luck!
did you have any problems with cutting your cat off..like o2 sensors check engine lights etc..???
  #5 (permalink)
Old 03-03-2008, 06:25 PM
95FordF150's Avatar
I had no problems with the o2 since it's ahead of the cat.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
