Pin Stripes - Ford Truck Enthusiasts Forums
Pin Stripes
Old 02-20-2008, 03:04 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Question Pin Stripes
Hey, Does anyone know where replacement oem or oem style pin stripes can be found? I have looked at LMC NPD etc. I can't find any. The closest I found was an incomplete set of NOS stripes on ebay.
Old 02-20-2008, 03:27 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
There are literally dozens of different types and colors, the major reason why no one reproduces them.
Look on your trucks Certification Label for the TAPE code.
Post it, I'll give you the original Ford part number.
The only problem with buying an original stripe kit is...it's prolly dried out, and so will be no good. That's a common problem with these kits.
Some ppl have had the stripes painted on.
FTE sponsor (obsolete Ford parts seller) GREEN SALES (800-543-4959) is prolly your best source for an original kit, but like I said, it'll prolly be NFG, and only usable for a pattern.
You will need to give them the TAPE code, because without it (even seeing a pic of one on the vehicle doesn't really help)...it's nearly impossible to get the correct p/n.
Old 02-20-2008, 10:40 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
I can help you with that. What kind of vehicle is it for?
Old 02-20-2008, 03:36 PM
jumpdawg jumpdawg is offline
jumpdawg is starting off with a positive reputation.
I need them too - for my '95 F-150 SuperCab XLT, only for the left fender that I replaced due to rust.
JumpDawg
Old 02-20-2008, 03:41 PM
Former Vendor
If you can either give me a call or e-mail me your vin I can locate which ones they are. 206-431-7331 or parts@y2kford.com. Lots of choices on these.
Thanks,
Kenny
Old 02-20-2008, 03:47 PM
Thanks! - will get the VIN and give you a call. Will also ask you about frame bushings and bolt for the same truck.
JumpDawg
Old 02-21-2008, 11:03 PM
Its for my 1995 F150. On the door sticker, my stripe code says G. Here is what my stripes look like. There are 2 different ones the first is the upper one and the second is the bottom one.
[IMG][/IMG]
Old 02-25-2008, 03:47 AM
I thought some of yall had some information about part numbers and where to get the pin stripes?
Old 02-25-2008, 08:25 AM
95F150SuperCab 95F150SuperCab is offline
95F150SuperCab is starting off with a positive reputation.
[/QUOTE]
Hello, I also need Stripe Tape for the tail gate of my truck. Its a '95 F150 white with bronze (santa fe) on the lower body. The problem I am having is the "tape" on the door jab sticker does not have a code. The tape stripe looks like the picture above but it is bronze with white pine stripes in it. The truck has the original paint and I am friends with the original owner so I know its all factory. The vin is 1FTEX14N35KB66016. Any help greatly appreciated.
Old 12-24-2008, 07:21 AM
CraigK's Avatar
CraigK CraigK is offline
CraigK is starting off with a positive reputation.
Did anyone ever find the pin stripes?
Old 12-24-2008, 10:05 AM
Its was a while ago but the guy at y2kfordparts found me the stripe that I needed. It was an original discontinued factory stripe.
Old 12-24-2008, 10:11 AM
Here is a picture of the newly painted tail gate with the stripe installed:
<img src="http://img223.imageshack.us/img223/4897/finished1iz8.jpg" alt="Image Hosted by ImageShack.us"/><br/>Shot with <a target="_new" href="http://profile.imageshack.us/camerabuy.php?model=KODAK+CX4200+DIGITAL+CAMERA&ma ke=EASTMAN+KODAK+COMPANY">KODAK CX4200 DIGITAL CAMERA</a> at 2008-12-24
Old 12-26-2008, 07:33 AM
Thanks for the reply. I'll check with them and see if they have what I need. I have looked at many different places. I completely forgot about this thread. I emailed them back when this thread was first started and never heard back. I'll have to try again. I'm glad it worked out for you. Hopefully, it will for me as well.
Old 12-26-2008, 08:16 AM
Quote:
I thought some of yall had information about part numbers and where to get pin stripes?
I assumed since this thread was dead for months, y'all had found what you wanted. Obviously not.
1995 F150 Styleside Regular or Super Cab Pickup ~ Tape Code G
F4TZ1520000KAD ..R/S Upper Body Stripe Kit-Light Opal/Silver / Obsolete
Last MSRP: $61.42
Munday Ford-Mercury in Bastrop TX has ONE: 503-312-3000
Meredith Ford in Meredith NH has ONE.
Dennison Ford in Bloomington IL has ONE: 800-322-9431
Friendly Ford in Las Vegas NV has ONE.
Obsolete parts vendor Green Sales Co. in Cincinnati OH has THREE: 800-543-4959
F4TZ1520001KAD .. L/S Upper Body Stripe Kit-Light Opal/Silver / Obsolete
Last MSRP: $44.43
Kinsel L/M in Beaumont TX has ONE: 800-816-2894
West Point Parts Center in Houston TX has ONE: 800-364-6444
Bob Allen Ford in Overland Park KS has one: 800-676-0675
Green Sales has TWO.
EDIT
You also want the lower stripes too, is that correct?
If so...I'll type a separate post with the info.
Old 12-26-2008, 08:58 AM
NumberDummy, Thanks for the part numbers. I can't believe you found these. How did you find out who had them?
To answer your question that you emailed me, yes I am wanting top and bottom, so both stripes.
Does it matter if the truck is regular cab short box, regular cab long box, extended cab short box, etc? Mine is regular cab long bed.
My truck's tape code is G.
Those descriptions sound right. I know that my truck has opal gray for its interior and the silver paint on the side.
Hey Kenny (y2kfordparts) can you get these? Another member of this site mstngmikegt wants some as well. I sent you an email.
'94 F150 Sport OEM Strip Kit? Necromancer 1987 - 1996 F150 & Larger F-Series Trucks 8 05-06-2014 06:21 PM
I need a pin stripe pic for a repaint fin reaper Excursion - King of SUVs 8 09-08-2012 03:34 PM
Factory pin stripe thomer 1987 - 1996 F150 & Larger F-Series Trucks 2 04-26-2010 05:34 AM
Ford pin striping source Billyclub 1999 - 2003 7.3L Power Stroke Diesel 10 08-20-2009 05:03 PM
Customer Access Wires . . mikewrt 1999 to 2016 Super Duty 1 10-19-2003 10:49 AM
Tags
1995, body, discontinued, duty, f150, ford, kits, oem, pin, pinstripes, side, stripe, stripes, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
