Transmission E40d I Think
Originally Posted by c00nhunterjoe
if its only when it makes the 3-4 shift then its the typical E4OD shift, there are many ways to remedy it,
Many ways to remedy? How many and what? Interesting can you explain?
Still waiting on the c00n cure. "comming soon"
Bill
I am a new member and just posted this in the pre-powerstroke forum.
Sounds like you have a similar prob to me. Any help would be greatfull.
94 7.3 turbo auto probs??
Yeasterday an I was driving to work and my trany started to make a wining sound and was slipping in drive. My OD light started to blink. I pulled over and everthing seemed fine untill I started to drive. It seemed to be fine in 1st and 2nd, but when it shifted into drive the wining and slipping started again.
I was about 100 miles into my commute with about 30 more to go, no cell service, so I limped into the work site in second gear.
To make it short I limped home in second gear and was able to drive in drive if I was going down hill. It was a long day!!
I have had a speed sensor failure in my other truck before which caused the trany to go into limp mode, but I think this problem is a little more than a speed sensor. The wining( which sounds like a cavitating hydraulic pump) and the slipping makes me think the trany is shot.
Does anyone have any ideas???
Thanks
Thanks
Walwal44
10-20-2014 03:32 PM
timnish
10-08-2007 09:52 AM
