drop axle personnel
drop axle personnel
I thought I posted this earlier today however, I can't find it so here it is again. I just put the drop axle from Mid-fifty on my 55; I have the C-clip type tie rod extensions. It appears that when I put the clips in the tie rod hole the end of the bolt is going to come through and hit the top of the tie rod. Currently the top of the tie rod is at the bottom lip of the C-clip. Has any of you guys have this issue how is the driving once you got an alignment & anymore advise you may have on your experience with the drop axle.
Thanks
Thanks
