Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-19-2008, 03:44 PM
luvemhot luvemhot is offline
Garage is empty, add now
luvemhot is starting off with a positive reputation.
using ATF as fuel
I was told about using used ATF at a 1 to 1 ratio with diesel. If I could cut my fuel bill by half I in. Any body doing this? Would it hurt anything? Thanks
__________________
Keith
1999.5 F350 4x4 lariat, CC, LB, DP Tunner F-5, ccv , 6637 air filter, SS HPX, Hutch mod, 5 inch exhaust, 3 gauge A pillar, BTS VB
99 Mustang GT convertible
1990 f 250 almost 1 millon miles
78 jeep cj-5
  #2 (permalink)
Old 02-19-2008, 06:15 PM
BLACK 6's Avatar
BLACK 6 BLACK 6 is offline
BLACK 6 is starting off with a positive reputation.
It has been covered in another thread, but what will the ATF cost you? Unless you are going to run new ATF in your truck, you run the risk of messing a few things up. To expand on that, used ATF has metal particulates floating in it that even filtering won't get out. suspended in the fluid like that they become a lot like sand in a sand blaster. Your injectors will definitely need replacing (quicker than normal). Everything that it comes in contact will wear at an accelerated rate...... how quick depends on the volume of matter in the ATF.
The way I see it, your playing Russian roulette if you use the contaminated ATF, you might do just fine, or your truck might fall apart. Not a chance I would take.
__________________
88 F250 Extended 4x4 7.3l
89 F350 Crew Cab 4x4 7.3l
04 F350 Crew Cab 4x4 6.0l
"You will know me by the scars I bear.
You will know me by the hate I swear."-OTEP
  #3 (permalink)
Old 02-19-2008, 07:44 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Take a sample of ANY waste motor oil or ATF and send it in to Blackstone for analysis. When you get the results back, check out all the heavy metals and nasty chemicals that are left in it. I'll bet you won't want to use it then.....................
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 02-19-2008, 09:34 PM
thanks I dont think I will look into this any more
__________________
Keith
78 jeep cj-5
Tags
1990, 73, atf, diesel, engine, f350, fuel, fuelina
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
