Carb Cleaner for Plug Removal
I read recently that Ford changed the TSB for the plug removal. In it, they state the use of Ford carb cleaner. What I am wondering, since I am going to the store for the final stuff before the S/C install, do I need to buy the Ford specific carb cleaner or will any name brand cleaner do the trick. It is just one more stop and a premium I would rather not pay if all things are equal.
Thanks,
Greg
Thanks,
Greg
http://www.fcsdchemicalsandlubricant...d/tsb/0819.pdf
For reference, here is the new TSB I am referring to.
Thanks,
Greg
Thanks,
Greg
If it makes people feel any better that the label says "Ford" on it great. However, it's probably just another penetrating lubricant like PB Blaster...which is a GREAT product! Heck they might even make it for Ford.
On a side note and just for giggles, I spoke to a friend that works at a pretty well known repair shop here in town. I asked with all the 5.4's he has worked on in reguards to spark plugs (if) he ever had one break off in the head. He said "nope but we have the tool just incase". They lube them, let it soak for a few minutes, and out they come.
He purchased a new 06 F150 with the spark plug problem heads...doesn't seem to worry about it, not one bit.
The reason they reccomend using the Kroil or the Ford Cleaner is not to loosen the threads, but rather to soften the carbon build up on the spark plug's sheild. That is the part that gets stuck to the wall of the head. The carbon 'glues' them together. Whatever you use needs to be able to wick it's way in,and once it does it needs to be able to soften the carbon build up. Leaving it too long will just allow the carbon to harden up again. There has not been a problem with the threads being seized up, so don;t think that is the reason for the TSB.
Originally Posted by peterman
I replaced my plugs 2 weeks ago. I have an 05 with the 5.4. I can't see a carburator cleaner being better than kroil as a penetrant. I used the kroil. Cracked the plugs about 1/8 turn and let it soak over night. A few minutes IMO is NOT enough. 40,000 miles and they did'nt come out easy.
Thanks,
Willie
Originally Posted by mrpositraction
Lol, so Ford switched the TSB on these horid heads to carb cleaner, not becuase it worked better, but to make a $ on the back end.
I'd hate to think that maybe they found something to cut the carbon a little better and updated the procedure. Maybe changed the engine temperature thing to keep it from evaporating before it did it's job. It's got to be the 1.00 profit per job that they can make every once in a while, it just has to be.
Originally Posted by play400
Notice "no lubricant on threads when installing new plugs but to coat part of the shield".
Been going that on my Harley plugs for 38 years.
Originally Posted by HamerDown
Steel threads going into a aluminum/alloy head and Ford doesn't expect me to use a touch of silver Antisize on the threads...yea right.
Originally Posted by littlewillie
Will you explain the "and they did'nt come out easy" part? I'm changing them on my 05 next weekend & trying to gather information from others.
Thanks,
Willie
Thanks,
Willie
What I meant was, you have to be patient and gentle. The kroil will soften the carbon, but they won't come out like they went in. You will here some screaching. As you loosen them, you will have to play with them. Did you read the TSB ? Follow it to the letter. Be patient. Let them soak. Don't force them, or they will break.
Gigemags05
02-19-2015 09:20 PM
JonB911
10-27-2014 08:32 AM
