Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-19-2008, 12:46 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke is starting off with a positive reputation.
No tow package, what would I need to tow a pop-up?
I am heading on a 2200 mile trip. What would we need to pull a small pop up? Other than a hitch and plug set?
Thanks
Its a '05 Ford Escape V6 automatic.
__________________
2002 PSD 4 door, F250, 4X4, Larait, 6637 Intake Mod, ATS Housing, 5" turbo back exhaust. 3.73's. Hypertech Stage III, set of gauges, BFG's 285/75-16. Every thing else 100% stock.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-19-2008, 02:50 PM
DoctorCAD is starting off with a positive reputation.
How heavy?
  #3 (permalink)
Old 02-19-2008, 08:02 PM
tcesni is new and has a neutral reputation at this point.
Also, what kind of terrain - Texas panhandle flat or heading for the Rockies?
  #4 (permalink)
Old 02-20-2008, 08:10 AM
Quote:
Originally Posted by DoctorCAD
How heavy?
Errr, not sure yet. It is going to be rented. I would guess less that 2K
__________________
  #5 (permalink)
Old 02-20-2008, 08:11 AM
Quote:
I-10 from Texas to San Deigo CA
__________________
  #6 (permalink)
Old 02-20-2008, 10:32 AM
99F150 is starting off with a positive reputation.
I take it you do not have the factory tow package that includes the under bumper receiver hitch, wireing and transmission cooler. That package gives your Escape a 3500# tow rating.
With out the factory tow package your Escape is rated for 2000# due to the lack of a trans cooler.
Most rented pop ups are 2000# or less so you should be fine. If you rent one that is larger than a 10' box with air on the roof, front storage trunk and a slide dinette you will be close to 3000#
if you stay under 2000# just need the hitch and lights plug (flat 4pin) unless TX requires trailer brakes for trailers over the weight of your rental pop up.
  #7 (permalink)
Old 02-20-2008, 11:18 AM
bigblock_drock is starting off with a positive reputation.
check your cooling system, make sure its got clean, and plenty of coolant.
__________________
The Fleet
1994 Mercury Grand Marguis 4.6 148,000 miles
2005 F-350 6.0 46,000 miles
2008 F-150 5.4 11000 miles
  #8 (permalink)
Old 02-20-2008, 01:46 PM
You have a trans cooler (all Escapes have one), what you are missing is the engine oil cooler. If you stay at 2000 lbs. or less you will be OK.
  #9 (permalink)
Old 02-29-2008, 11:27 AM
xkpsanit is starting off with a positive reputation.
I tried pullin' my father's "pop-up" which weighs in at over 2000# in my 02 with a towing package. Took it for a a 20 mile test drive and found she struggled pretty hard. With me being very self-concious about heat in an automatic transmission and no way to monitor it in my rig, I decided to borrow his fullsize GMC for our 900 mile round trip. That and the fact that I couldn't see behind the camper due to the overall width of the escape rendered the mirrors useless. In my opinion, ma's '94 T-bird with a 4.6 and a 2000# tow rating pulls this same RV with much more ease than my baby rig. Should'a had a V8 Would'a used the bird but daddy has a CD player and wifey likes to rock...
  #10 (permalink)
Old 02-29-2008, 02:22 PM
i find it hard to believe the v6 is that under powered. my 99 ranger with the 2.5 l four and 5speed tows my 3000# tent camper fine and my 05 escape with the 2.3l four is much snappier than the ranger.
  #11 (permalink)
Old 03-11-2008, 05:46 PM
abusch is starting off with a positive reputation.
I have a 2008 V6 Limited 4x4 Escape. And I tow a 16 ft. XTRAIL camper trailer. It is 2200 lbs dry. I have added the electronic brake control to run the trailer brakes. Other than that... The escape tows it fine. I have added an extra tranny cooler, changed the trans fluid to AMSOIL, as well as the transfer case and rear differential oil to AMSOIL. I have done this because of AMSOIL's high heat rating. I try not to exceed 55 mph. but have towed at much higher speeds on the freeway. I also only tow in 3rd gear, no overdrive engaged. This is a direct drive gear and helps reduce heat buildup and slippage in the tranny. Happy towing
  #12 (permalink)
Old 03-12-2008, 09:09 AM
Quote:
It isn't underpowered, just underbraked
  #13 (permalink)
Old 03-12-2008, 09:22 AM
Dr.Cad. The braking is easy fix, add a brake controller to tow veh. Any trailer of that weight built in last 10+ years will have electric brakes standard or can be added. Most states require trailer brakes any way over a certain weight usually around 2000#.
I would be pulling my camper behind the Escape instead of the Ranger, but I am concerned about the cooling system and transaxle of the 4cy. 5speed model that I have.
  #14 (permalink)
Old 03-12-2008, 07:07 PM
My 2800 pound 19' bass boat has no brakes.
Next...
  #15 (permalink)
Old 03-14-2008, 10:59 AM
penair78 is starting off with a positive reputation.
i have a '05 limited v6 awd and i pulled a 5'x10' enclosed trailer from san antonio to san diego with no problem. going to do it again next month but with my quad in it and a new tranny.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
