High idle after cleaning throttle body? - Ford Truck Enthusiasts Forums
Old 02-19-2008, 06:37 AM
xjbeast96's Avatar
xjbeast96 xjbeast96 is offline
xjbeast96 is starting off with a positive reputation.
Exclamation High idle after cleaning throttle body?
Hello FTE ! have a question, found a few leaking vacuumm lines and fixed those as well as cleaned throttle body with some throttle plate cleaner...the stumble is gone out of my idle, but my idle seems higher now. i dont have a tac in my truck...
the truck is a 96 f150 4.9 5speed short box...
thanks
aaron
Old 02-19-2008, 06:52 AM
bluesman2333's Avatar
bluesman2333 bluesman2333 is offline
bluesman2333 is starting off with a positive reputation.
Pull the IAC and clean it with O2 safe cleaner. Make sure the spool is free and leave it to dry for about 10 minutes before reinstall. I always set the base idle on a warm engine with AC off then plug the IAC connector in. Seems to help.
Old 02-19-2008, 10:08 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
reset computer after you clean the iac.
Old 02-19-2008, 02:36 PM
alxsnmr alxsnmr is offline
alxsnmr is gaining momentum as a positive member of FTE.
You probably unintentionaly got crude that washed into the IAC from your cleaning of the throttle plates, so I agree with all the above statements.
Old 02-19-2008, 02:55 PM
xjbeast96's Avatar
Smile
Thank you for the replies ! I will try that tonight ....Thanks again
Old 02-22-2008, 09:48 PM
dpayne1976 dpayne1976 is offline
dpayne1976 is starting off with a positive reputation.
I have a question regarding the cleaning of the throttlebody/IAC. What is the best cleaner to use? Obviously you cant just use carb cleaner. I am a Ford convert meaning I was a hard-core Chevy man until I bought my first Ford a few years ago and I dont own any GM vehicles anymore. I have had Fords exclusively with the exception of my wife wanting a GMC Envoy......junk. Anyway, I appreciate your experience and guidance.
Dale
Old 02-22-2008, 09:53 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
You have to be very careful when cleaning a throttle body, technically you're not suppose to clean them.
If you completely wash out the inside of them by going nuts, you wash the special film off the bore where the butterflies are and you will have a high-idle problem because too much air is able to go by the blades.
The factory puts a sticker on there telling you not to clean it.
Old 02-22-2008, 10:03 PM
I was schooled on mostly GM products. You could use just about anything to clean them. Is there a safe and effective way to go about cleaning the Ford induction systems without damage? I think that my IAC needs cleaning as it idle surges when first started, I just got this truck in question a few weeks ago and its been super cold here. When I first start the truck it idles high for a few seconds and then normal then rises again. It does this a few times before leveling out to a normal idle. The truck runs great overall other than the first start idle surge. After the truck warms up it will start and idle normally. Thanks for the advice.
Old 02-22-2008, 10:20 PM
It's suppose to idle high at first startup then come down to a normal idle after a moment.
You can take the IAC off and clean it and re-install it with a new gasket. I would remove the neg batt terminal and clear the computer so it can re-learn its strategies.
You can take the TB off and use a toothbrush and lightly clean the carbon off the back of the bores but don't go nuts and try to get it all off and have it clean as a whistle.
Old 02-22-2008, 10:26 PM
Thanks Stang. I may just take the IAC off and do a visual inspection to see how much build up if any is on there. The same with the TB. 'Preciate the info.
Dale
Old 02-22-2008, 10:32 PM
Take the two intake ducts off the front of the TB and use your hand to open the throttle blades and look inside with a flashlight.
The carbon on the back of the TB doesn't usually cause a problem...so it doesn't really need to be cleaned. The IAC is what causes a problem because it's how the computer controls the idle and sometimes it will get stuck or gummed up.
Old 03-17-2008, 06:29 AM
xjbeast96's Avatar
Exclamation
Ok I tried with the cleaning again. Still High idle. So i went to FORD and bought a new IAC. Put it on ...no change????? Still HIgh. ? Could i have gotten something into the throttle body. I have a check engine light on. High Idle Circuit Code?
Old 03-17-2008, 06:47 AM
Did you set the base idle with a warm engine? The high idle can be caused by vacuum leaks or the idle being set too high by the screw. Go over every hose with a fine toothed comb then with the IAC disconnected on a warm engine, turn down the idle screw until the RPM is at the sticker spec. If you can't turn it down using the screw, then you still have a vacuum leak.
Old 03-19-2008, 10:08 PM
Creel Creel is offline
Creel is starting off with a positive reputation.
Fixed problem with fluctuating idle on start up mine other day by accident. Went to start it up and died right after starting, acted like battery was dead so I messed with cables and got it going again, started it up and turned on headlights, bam it went dead again, so I got out battery terminal cleaner and cleaned posts and cables, runs perfect now, rock solid idle. No idea how much I've spent in past trying to fix this problem, figures it was something stupid simple.
plastic bushing on throttle body What was I thinking 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-19-2014 07:27 AM
96 f250 5.8 idle surging when i come to a stop need help! texasdiesel98 1987 - 1996 F150 & Larger F-Series Trucks 4 07-25-2013 01:45 PM
Dirty throttle body/ rough idle davisenvy 1997-2006 Expedition & Navigator 2 12-18-2010 09:21 AM
Cleaning EGR and throttle body-'89 F-250 351W WINGNUT- 1987 - 1996 F150 & Larger F-Series Trucks 4 08-11-2010 08:20 PM
Bad throttle body? Brian429 2004 - 2008 F150 1 04-15-2010 11:54 AM
Tags
1993, 1998, 46, body, clean, cleaning, expedition, explorer, firebird, ford, high, idle, remove, sfi, throttle, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
