Replaced EGR sensor and valve still picking up codes??????
the EGR doesn't work alone, it has controls. Follow the vacuum lines from the EGR and see where they stop. There is a relay-controlled solenoid at the other end that gets corroded and may stop the solenoid from working.
Anotherwards the EGR is vacuum controlled, a broken vacuum line will produce the same codes even if the EGR and relys are OK.
OR>>>> did you clear the old codes??? See Ford fuelinjection.com there is a simple procedure to erase old stored codes. Or you could disconnect the battery for a few minutes.
Originally Posted by quicklook2
disconnect the battery for 15-30 minutes to clear codes.
on
There's another good reason not to disconnect the battery, doing so also wipes out the learning the computer has done on the fuel and ignition maps, and it will take some time and driving around to relearn everything. For some problems this can be a good thing, but on others it just makes diagnosis harder because the motor will behave completely different and it may mask the problem you're trying to fix, fooling you into thinking you fixed it when you really haven't.
