what brake system to use rockwell 5 ton
on
Soon i will be building the brake system. Mr Boyce at Boyce equipment says to use my factory booster and use his 5 ton air pack in conjunction. is this a good idea or is there a hydroboost system that i should use instead? 1978 bronco is the build subject.
are you going to or are you already using wheel brakes? if so i would go with a hydroboost system. i have hydroboost on my bronco and i can lock up all four wheels with no problem (not always a good thing) if i stand on it. with a vacuum system i always had trouble with it and i had to pump the brakes a lot. i got my system from a superduty but they also come on new mustangs as well. make sure to get the hoses. you will prolly have to get the fitting adapters from summit racing but they aren't too expensive. also you will need to run a pressure line from your p/s pump so make sure your pump is up to the task. if you havent already swapped over i strongly suggest a saginaw pump (canned ham) b/c it can and will take the abuse.
-cutts-
-cutts-
Originally Posted by chrono4
The only issue with the pinion brakes is the streetability issue. I know its a big truck and all, but if he plans on any street driving, or even good stopping in the mud, it could pose a problem. Unless of course he is or goes fully locked, then hell go for it.
pinion brakes stop WAY WAY better than 4 wheel disc.......everytime i drive a vehicle with pinion brakes it is a shock......they will put your head through the window.....but you have to watch out for pinion brakes if your not locked b/c it would basically be trying to stop from 1 tire.....if your welded f/r just use pinion brakes.....if your not welded, get to welding at least the rear and run pinion brakes anyways......but if your stuck on wheel brakes i can get you hooked up for some 4 wheel discs that will work with 5 tons.....
Well, I knew the street driving comment was going to come across wrong. Even if it was just a panic stop in the mud, He would want to be fully locked with a pinion brake. No personal exprience with any of this, its all just what I've read.
on
wow thanks for all the feedback, i didnt even notice this thread until crazy redneck said something. anyhow, heres the list:
i do not want pinion brakes.
1: i am going to offroad the carp out of this thing, and take pictures as soon as its done, wheeling the nevada trails.
2:do not be fooled by the nice paint. i dont care about scratches. notice theres no intentional ''BLING". i would have camoflaged it if it werent for the fact that i have never had a vehicle that loocked nice, and i do like nice looking vehicles.
3: chrome on the hood hinges is there only to eliminate corrosion. (powdercoating would not fill in all the crevices).
4: yes i am going to drive this on the street. the planet is covered with streets, i want to drive on them.
5: only the rear has a detroit locker.
4 wheel discs you say? i am very interested.
Glad to hear it won't be a cakemobile, again, I'm jealous
