parking brake gets stuck - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-19-2008, 02:50 AM
ac91725 ac91725 is offline
ac91725 is starting off with a positive reputation.
83 ford ranger notices the parking brake gets stuck my parking brake half *** works feels loose when i press the parking brake. but you kina feel it when its in gauged. what can i do to make it not stuck i have to move the truck forward and back to kinda release it.
Old 02-19-2008, 01:57 PM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
Try spraying WD-40 on the cables to the rear wheels. Give them a good soaking and then try applying and releasing the parking brakes several times. It may take several applications of WD-40 to break down the rust and corrosion that has built up over the years inside the cables.
Old 02-19-2008, 02:10 PM
jason867's Avatar
jason867 jason867 is offline
jason867 is starting off with a positive reputation.
I recently changed my rear drum brakes on my 88 ranger, and I started experiencing the same exact thing you are describing. Mine worked fine before I changed the brakes. I haven't tried fixing it yet, cause I busted my front piston lol.
Mine seemed to get a little better the more I used it...
Old 02-19-2008, 11:22 PM
well i took my truck to les schwab and man each side has different drums. so everything has to be re done.
Old 02-20-2008, 07:45 AM
jason867's Avatar
lol, I believe there are 9" and 10" drums for the older rangers...
Old 02-20-2008, 09:35 AM
ya but one side has 9 inch and the other has a 10 inch drum
Old 02-20-2008, 09:31 PM
98range 98range is offline
98range is starting off with a positive reputation.
Best thing to do is replace the brake cable. A crack in the rubber lets in moisture and if salt is used on roads in winter the corrosion binds things up.
Old 02-21-2008, 09:25 AM
michigan66's Avatar
Hi ac91725, how did you wind up with two different size brake drums?
Old 02-21-2008, 08:30 PM
BuffmanLT1 BuffmanLT1 is offline
BuffmanLT1 is starting off with a positive reputation.
I've noticed the same thing with my ranger. Driver's side pB assembly on the shoe always seemed hard. Finally starting to stick now that's it's cold. I was going to cut that side off and just use the other side till i saw the driver's side is tied to the main cable...
BTW WD40 will not break down rust. it's a lubricant. You need Kroil or PB blaster.
Brakes stuck codeman2443 1987 - 1996 F150 & Larger F-Series Trucks 8 08-19-2014 07:46 PM
2004 Eddie Bauer Expedition stuck raw23062 Expedition & Navigator 3 06-11-2014 09:54 PM
Parking Brake Issue - 03 FOrd Excursion tpozz Excursion - King of SUVs 1 04-26-2011 01:16 PM
Shifter's stuck man, shifter's stuck ColdRavioli 1967 - 1972 F-100 & Larger F-Series Trucks 3 03-31-2011 09:04 AM
Parking brake sticking falcon5 1997 - 2003 F150 4 06-20-2004 08:25 PM
Tags
83, 91, brake, brakes, edge, emergency, f350, ford, forum, parking, ranger, release, sticking, stuck, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
