Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-18-2008, 02:24 PM
coop25 coop25 is offline
coop25 is starting off with a positive reputation.
i also have a 6.0 f-350 but its a 2005. what are the major problems or concerns with runnung svo if you start on diesel to warm the tank then switch to svo? dont the same priciples apply to a 6.0 then that of a 7.3 that has been successful on svo ( with respect to hp)?
  #17 (permalink)
Old 11-19-2008, 05:48 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold
Quote:
Originally Posted by Phydeaux88 View Post
spuck
right click on my name at the top of this post then select "send a private message"
He can't. Members with fewer than 25 posts cannot send or receive PM's. One of you will have to e-mail the other.
__________________
Scott - FTE moderator
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods.
Hers: 98 Navigator, 5.4, AT, 4x4, Old.....but still a Lincoln ;-)
  #18 (permalink)
Old 05-29-2009, 12:11 PM
dlag951 dlag951 is offline
dlag951 is starting off with a positive reputation.
2000 7.3 trb diesel
i was wondering if i could run vegetable oil in my truck with no modifications.?
  #19 (permalink)
Old 05-29-2009, 06:11 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
Biodiesel Guru
fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold
No.......................
__________________
FABMANDELUX.
Don.
Oregon Chapter Leader: To join the Oregon Chapter, click HERE
  #20 (permalink)
Old 05-30-2009, 08:36 PM
Z-MAN's Avatar
Z-MAN Z-MAN is offline
Z-MAN is starting off with a positive reputation.
B-100 in the 6.0 no problem, if made right.
my truck loves it
__________________
2003 CC/SB SRW BLK 6.0 LARIAT FX4 4X4 SIX-GUN BUNDLE/W SPEED-LOADER, SCT3 W/SPARTAN TUNES,TRIPLE GAUGE A-PILLAR , PML TRANS PAN. ARP STUDS. GONE BIO, I.A.F.F. local #3970
  #21 (permalink)
Old 06-02-2009, 09:38 AM
kirkharrod kirkharrod is offline
kirkharrod is starting off with a positive reputation.
Do not single tank with waste vegetable oil! You need a heated second tank to safely use WVO without killing your engine. To get some understanding of using grease for fuel, check out:
Greasecar Vegetable Fuel Systems
Frybrid Vegetable Oil Fuel Systems
Forums - Powered by Eve For Enterprise
__________________
2002 F-250 Super Cab, 225,000 miles, 25,000 on WVO; Greasecar conversion, 140 gal grease tank, 30 plate heat exchanger, 6637 air filter w/ Pete's cover, CAT ELC, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, ISSPro trans temp, boost, exhaust gas temp, electric fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. ZERO grease related problems.
  #22 (permalink)
Old 06-08-2009, 12:28 AM
binuya's Avatar
binuya binuya is online now
binuya is gaining momentum as a positive member of FTE.
My understanding on the early 6.0 is that the injection system (mainly the injectors themselves) is quite a bit more sensitive than the tolerant 7.3. Personally, I wouldn't do the SVO route, but properly made bio would be no issue.
I might suggest going to 'biodiesel and svo forums' and do a search on the 6.0. There are some great well informed posts on the subjects of both SVO and bio.
  #23 (permalink)
Old 08-14-2009, 05:48 PM
spuck77 spuck77 is offline
spuck77 is starting off with a positive reputation.
I ran a full tank of svo with no problems. I know, eventually I would likely have problems. I do know of a guy here that filters the svo down to 4 microns and has over 100k with no issues. Maybe he's just lucky!I have not done a lot on this subject due to lack of $ to purchase the necessary stuff to process into bio. There is nowhere locally to purchase at the pump.
Tags
60 , 60l , 73 , 88 , biodiesel , conversion , f250 , ford , kits , oil , run , svo , turbo , vegetable , veggie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
