EBPV Question
both wires need to be cut to do it the way i did. u unplugged the connector, cut the ground wire (forget the color, i'll check) but the color goes to only black on the back side of the connector, so you have to be sure to get the correct wire on the back side (make any sense?). i got my power from the 15 amp fuse that operates the radio, so it couldnt get power when the trucks off. my negative i grounded to the windshield wiper motor bolt. br sure to get a good USA toggle switch.
heres my write-up on it,
https://www.ford-trucks.com/forums/6...ylor-ebpv.html
check my gally for pics.
i'm sure you'll love it!
