Ford F53 V10 motorhome - Where is OBD? - Ford Truck Enthusiasts Forums
Old 02-18-2008, 09:07 PM
chuckf201 chuckf201 is offline
chuckf201 is starting off with a positive reputation.
Can't seem to locate the Data-port.
Any help will be appreciated.
Also, do you have a thread for Ford motorhomes?
Old 02-18-2008, 09:21 PM
super 6.8 super 6.8 is online now
super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.
If it is not under the dash on drivers side I am not sure.
Old 02-19-2008, 08:44 AM
jonrjen's Avatar
jonrjen jonrjen is offline
jonrjen is a splendid one to beholdjonrjen is a splendid one to beholdjonrjen is a splendid one to beholdjonrjen is a splendid one to beholdjonrjen is a splendid one to beholdjonrjen is a splendid one to beholdjonrjen is a splendid one to behold
It should be under the dash near the steering wheel location. You may want to try logging onto www.rv.net and go to the Class A motorhome section and try posting this same question. A lot of great information located on that site for all RVing subjects.
Old 02-20-2008, 07:03 AM
EXPYBOAT01's Avatar
EXPYBOAT01 EXPYBOAT01 is offline
EXPYBOAT01 is starting off with a positive reputation.
Chuck,
Mine was on steering column, under the plastic shrouds, next to my right knee.
As mentioned above, search F53's on RV.net for more info.
Old 02-20-2008, 11:48 AM
tps0424 tps0424 is offline
tps0424 is starting off with a positive reputation.
I haven't gone out and looked for mine yet but, my understanding is that it is within reach of the driver's seat, to the right of the steering wheel, under the dash.
There is a Ford Motorhome Chassis Forum on iRV2.com
http://irv2.infopop.cc/eve/forums/a/frm/f/5931040402
It's all Ford motorhome chassis but, there's a lot of F53 discussion. Probably more than the others combined.
Old 02-20-2008, 03:54 PM
bobc30_2 bobc30_2 is offline
bobc30_2 is starting off with a positive reputation.
Hi There I have A 1999 holiday rambler Vacationner . I just found mine it is under the steering cover on the right side it is mounted on the bracket that holds the steering wheel when it was a chasse .its hard to get to the screws to remove them .I moved mine on the face of the dash just under the dash, Hope this helps Bob
1967 Ford Motorhome 62FE4x4 1999 to 2016 Super Duty 0 06-10-2016 11:03 AM
My first ford Cgerman New Member Introductions 9 05-31-2016 03:59 PM
1969 Ford Travel Queen cgr5663 1968-2013 Full Size Vans 1 04-13-2016 07:49 AM
Ford Chassis Motorhome Sales Up edtahaney 1968-2013 Full Size Vans 0 08-26-2014 01:43 PM
1983 ford 21 foot motorhome-question. carsonbeaulieu 1968-2013 Full Size Vans 5 08-05-2010 06:17 PM
Tags
1341, 2006, 5931040402, cc, eve, f53, ford, forums, frm, infopop, irv2, locator, national, obd, seabreeze, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
