PO125 code - Ford Truck Enthusiasts Forums
PO125 code
Old 02-18-2008, 07:31 PM
stickboy42461 stickboy42461 is offline
stickboy42461 is starting off with a positive reputation.
PO125 code
I was reading some of the other posts about this code and have some questions. I periodically get this code and clear it. I t may stay gone for a while and it may not. I think I am going to change the TSTAT out and start at this point. I would like to Know which TSTAT to use. Do I need to use the 180 or 195 I need help? I have a 2000 4x4 with a 4.6L in it. I have not noticed the temp guage not working maybe it has been working a little slow. Will this repair my problem.Any help will be appreciated. Thanks in advance.
Old 02-18-2008, 08:13 PM
antony25 antony25 is offline
antony25 is starting off with a positive reputation.
Bad thermostat. Do not use a fail safe t-stat and be sure it is a 195*
Old 02-19-2008, 05:45 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Agreed. Your old thermostat is getting slow to respond.
Stick with the stock unit.
Steve
Old 02-22-2008, 02:30 AM
Zappo90744 Zappo90744 is offline
Zappo90744 is starting off with a positive reputation.
So would this also apply to me? I went yesterday to get a Smog Check on my 2000 Lincoln Town Car which has a Ford 4.6L and failed with code PO125. Low ECT for Closed Loop Fuel Ctrl. I just had a new intake manifold and thermostat put in last year!
Old 02-22-2008, 04:11 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Sounds like it. The engine is not reaching the proper operating temp.
Always use a 195 Thermostat.
Old 02-22-2008, 01:58 PM
Great...thanx for the advise....I'll replace it today. Hopefully that will take care of my problem. I'm assuming if it continues next thing to look at is my temperature sensor right?
Old 02-22-2008, 02:56 PM
Never had one come back to find out.
Steve
Old 02-23-2008, 03:24 PM
Great thanks! Just changed it and reset the computer and everything seems A okay!!! Thanks a million for the advise.
T-Stat Leak Jake_f16 1999 - 2003 7.3L Power Stroke Diesel 9 09-07-2012 08:14 PM
T-stat change help YoungFordAddict66 1994.5 - 1997 7.3L Power Stroke Diesel 33 03-14-2012 02:37 PM
So I installed my 203* thermostat.... KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 9 08-11-2011 05:19 PM
ELC coolant superduty4x4 1994.5 - 1997 7.3L Power Stroke Diesel 11 05-19-2010 07:50 PM
Temp gauge not working or t-stat stuck? will 1987 - 1996 F150 & Larger F-Series Trucks 2 09-21-2004 04:00 PM
Tags
02, 150, 2000, 2003, 46, 46l, 50, code, ect, explorer, f150, failsafe, ford, po125, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
