Bed Cover and 5th Wheel Hitch - Ford Truck Enthusiasts Forums
Old 02-18-2008, 07:13 PM
wpeloqui's Avatar
wpeloqui wpeloqui is offline
wpeloqui is starting off with a positive reputation.
Hi,
Can anyone recommend a bed cover that will work normally and then either flip or roll out of the way when I tow my 5th wheel trailer?
Thanks,
Willie
Old 02-18-2008, 07:28 PM
SUPERDUTY_08 SUPERDUTY_08 is offline
SUPERDUTY_08 is starting off with a positive reputation.
access roll cover or truxedo cover. I had the access cover on my old 250 and it worked great with my husky slider hitch. I have not gotten a new cover for my new 2008 F350, but I will be getting a truxedo.
Old 02-18-2008, 11:50 PM
c.f.moore c.f.moore is offline
c.f.moore is starting off with a positive reputation.
I use the Truxedo LoPro on my '05. Works great, when down, it keeps most things dry (I haul seasoned hardwood for furniture building). It holds 3 ft of wet snow very well.
When I'm towing my 5th wheel, it rolls up and stows nicely at the front of the box. As soon as I unhook from the trlr, I roll out the Truxedo cover to hide what ever is in the bed, from prying eyes.
Good luck
Old 02-19-2008, 09:53 AM
rphlipper's Avatar
rphlipper rphlipper is offline
rphlipper is starting off with a positive reputation.
Pace Edwards
I have a Pace Edwards tonneau cover on my truck. It works great to keep people out when not towing and rolls out of the way when I am towing my 5th wheel. I do have 2 bungies I leave in place to pull the hitch flat when closing the cover, they remain hooked to the front hooks in the bed of the truck. I also turn the fifth wheel hitch handle over (facing down) before closing the cover.
Old 02-20-2008, 05:36 PM
MeyerzF350 MeyerzF350 is offline
MeyerzF350 is starting off with a positive reputation.
I just installed a Retrax. Very easy. I believe its the lightest one available which I needed because I tow a very heavy 5er.
Old 02-22-2008, 02:00 PM
RealTruckMan RealTruckMan is offline
FTE Sponsor
RealTruckMan is gaining momentum as a positive member of FTE.
Any and all mentioned above I have available for your truck. Send a pm and lets get you one.
Old 03-02-2008, 10:33 PM
novice psd novice psd is offline
novice psd is gaining momentum as a positive member of FTE.
I have a rollup cover from real truck. Great cover, its aluminum and supposedly will hold up 400lbs or so on top. It will also slide over the hitch.
Old 03-03-2008, 09:38 AM
Eric C.'s Avatar
Eric C. Eric C. is offline
Eric C. is starting off with a positive reputation.
I have a Pace Edwards Jack Rabbit and love it because I can lock up the back end when carrying tools back there and roll it up for using the bed or towing the 5th wheel. Because it's a hard one I've not had a break in even in Chicago for almost a year while working.
Old 03-03-2008, 11:08 PM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE.cangim is gaining momentum as a positive member of FTE.
I would think about any roll up cover would work. I have seen one that folds up as well that may or may not work. I have thought about one, but then decided with a louvered tail gate it would look kinda silly.
5th wheel Prep Package hole cover trouble houstonmr 6.7L Power Stroke Diesel 21 12-21-2016 11:32 PM
new f350 kenscomet 1999 to 2016 Super Duty 4 01-12-2014 09:46 PM
5th Wheel Bed Cover? redneck1877 Aftermarket Products 0 09-13-2005 05:52 AM
Covering 5th wheel bedliner hole. afinepoint Paint & Bodywork 1 01-18-2004 07:26 PM
Extended Warranty Voided with 5th wheel!!! jfralph 1999 to 2016 Super Duty 10 11-26-2003 02:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
