Downpipe Installation Pics
Old 02-18-2008, 03:40 PM
stevorino's Avatar
stevorino
stevorino is offline
I thought these pics might help for anyone preparing to install a new downpipe. My buddy down the street and I did both of our trucks at the same time. The learning curve made a big difference. The first one took 3 hours because of fighting the cat. It just wouldn't come off. The second one took about an hour because it was already straight piped. I haven't noticed better gas mileage yet. Probably for two reasons:
1. It's colder right now
2. The first thing I noticed after doing this mod was that the engine revved up much faster(less turbo lag) so it's easier to stomp on the pedal. Little by little, I have been trying to lay off, because it's just sooo much easier to push those RPM's up.
Hope this helps
Cutting off the Cobra head - I recommend a good blade like a Lennox. I cut off two pipes with one of these blades. A lesser blade would have struggled.
Finishing off the cut:
The old flat pipe is gone!
Checking the fit after the pinch weld is bent back. After notching it with the sawzall I used a 2x4 against the engine block. It bent very easily. I just bent back the heat shield instead of cutting it off completely and I haven't had any problems with it making any rattling. I figured that was better than mangling the sheet metal trying to cut it off in that tight little space.
It's tight in here after the clamp goes on. I know a lot of guys recommend using the other type of clamp, but I just used the one that came with the pipe. It hasn't leaked after 2 months.
My engine seemed to be mounted a little farther forward than my buddy's down the street. You can see how mush space is left between the cab and the pipe.About 1/2".
The pipe installed from the top:
The new cat delete pipe:
What a difference from the old one:
Old 02-18-2008, 04:03 PM
WALJON's Avatar
WALJON
WALJON is offline
Nice pics. STEVO !!
Old 02-18-2008, 04:28 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
rep points sent
Old 02-18-2008, 06:47 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Thumbs up
X 2 with cOOn, rep sent. you are a good photographer (spel?)
Old 02-18-2008, 06:50 PM
FARM69's Avatar
FARM69
FARM69 is offline
Ditto on the pics. Looks good man.
Old 02-18-2008, 07:20 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
Ditto on the ditto. Rep points sent. Now I might even want to try this myself. Looks like I "need" to get a sawzall.
Old 02-18-2008, 08:27 PM
stevorino's Avatar
stevorino
Thanks, guys. I'm not a photographer, but I did have to take it as a class in Architecture school. I noticed for the longest time no one has posted pics of the downpipe install so I thought it would help since everybody asks the same questions about it. Seems logical, since it's the first mod everybody recommends.
Mooseman, I have had that "need" so many times that I have a pretty good collection of tools. I can buy and feel good about those purchases. I mean in the long run they save money, right?
Old 02-18-2008, 08:44 PM
RubberDuck's Avatar
RubberDuck
RubberDuck is offline
Awsome job, rep sent.
Old 02-18-2008, 09:45 PM
jdap's Avatar
jdap
jdap is offline
Great job with the pics! Reps on the way. I just wish i had seen this last week when i was throwin mine in, it would have made life a lot easier.
Old 02-18-2008, 11:51 PM
coreyallan01's Avatar
coreyallan01
coreyallan01 is offline
Nice man, very nice.... My 02 for anybody wanting to do this mod would be to wrap the dp w exhaust wrap like I did b4 I slid into place that way even if it looks good on the clearence side you wont have to contend w a rattle if she torques at any point ....
Old 02-18-2008, 11:53 PM
maverick1701's Avatar
maverick1701
maverick1701 is offline
I am going to be buying a downpipe and installing in a week or so. You saved me a lot of stress and time. Thanks for the pics.
Old 02-19-2008, 02:15 AM
Smokin&Strokin's Avatar
Smokin&Strokin
Smokin&Strokin is offline
Great pics man...this will help out when i install my exhaust. Off topic a bit...do these trucks sound and perform better with the stock dp and straights?
Old 02-19-2008, 11:13 AM
coreyallan01
Smo&Stro, thats a big NO, that 444 loves to exhale, the first mod I ever did was the 3" dp to a 4"- 4' strait section to a 45 turn down. Big difference especially up on the top 85-90 mph and still good torque. Cobra out Boa in....
Old 02-19-2008, 11:59 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Nice write up, reps sent. It's n my fav's folder. Good job.
Old 02-19-2008, 03:54 PM
secondarychaos's Avatar
secondarychaos
secondarychaos is offline
very nice pics!
Is that Seriously what my downpipe looks like?
that looks like it was hit flat with a sledgehammer...
that needs to be fixed!
Quick Reply: Downpipe Installation Pics
