Hi guys and gals , my 1991 f150 shutoff yesterday and now it wont start engine cranks over(300-6) but relays arent kicking in . relays are all getting power to the main side but nothing to the activation side with the key cranking. if I wire around the relays I can activate the fuel pumps etc. Not sure were to go next possibly bad Computer ? dont want to spend the 200 dollars on a computer to find out it is something simple.
also tested all fusees and checked the relays they test good. any help would be greatly appreciated.
Forgot to mention I checked that it is good also tried a blast of starting fluid no luck there so im assuming there is no spark either thanks for the reply, just noticed i listed it as a 91 it is actually a 92
you have a (300-6) and no spark...., my brother had that problem on the work truck .... he changed the modual on the bottom of the distributer (about $100) (and you need to buy a special socket) and it started......
oops forgot to state the relays work out of the truck when you put them in the truck they dont work tested the pumps by hot wiring them to the battery with a long wire
