Edge w/ supercharger
I posted this in the supercharger section, but got no response, so I thought I'd run it here:
I have a 2006 F-150 5.4 w/ a Magnacharger w/ Magnaflow exhaust. The ECU runs a custom program for the the charger and I don't want to change that. However, I'd like to be able to monitor the various systems that the Edge can do. I was going to get some gauges, but the costs began to outweigh the cost of the Edge.
The question is this: can I run the Edge without having it alter my current program? I don't want to screw up the custom map. I just want the guages and ability to read codes.
Thanks!
-chris
Thanks!
-chris
Originally Posted by ford-lover
I purchased the Edge in August 2007 for my new 07 F150 XLT SCAB 5.4L. I stay with the stock program (level 0) and only use the Edge to monitor other parameters ( scar of voiding the warranty).
Based on that, I think you are okay.
I think that with the Edge set on the stock program, it's actually writing that program to the PCM. Think about it, when you flip it from a performance program back to stock, it re-writes all those parameters so the engine runs stock. It's obviously changing something.
I'd be worried it was going to overwrite everything.
I do bet you could get an Edge dealer to copy your parameters onto a custom program and just run that one.
This may work...
Check out the MSD Dashhawk... It gives similar monitoring capabilites as the Edge without the programming features...
http://www.dashhawk.com/
Originally Posted by JimTex
I don't think it does if all you do is hook it up and set the gauges to what you want on the display. I think you would have to load one of the 3 programs it offers for it to change anything. But, I don't know anything.
the nice thing about getting the edge though, is that it is a lot easier and faster than hooking up seperate mechanical/electrical gauges.
as for using the edge on stock to avoid warranty problems... i wouldnt worry about it.. unless you use level 3 and mess with the settings without doing it correctly. if you run the required fuel for the level you pick, you should be fine... there are too many edge users out there doing just fine to think otherwise.
and what is a wideband???
My Edge arrived today and according to the manual I should have no problems.
Does anyone know where to get the proper paint to match my dash for the pod?
Hey 43Duc,
If your interior is "grey". Please check out the following post ....
https://www.ford-trucks.com/forums/6...e-evo-pod.html
Hey 43Duc,
