260k PS noob question
Good evening everyone, I've got a question for the experts here. I am looking at a one owner 97 f350 crew cab srw power stroke 4x4 w 260k on it from Texas. It has 4.10s and an automatic and was 5th wheeled. The indipendent dealer(who got it from an auction) says it has a new/rebuilt tranny, is there any way I can confirm that myself? How many miles is a well taken care of 7.3 capable of? I had the identical truck 6years ago and have regreted selling it ever since..... If I have a prepurchase inspection done at a Ford dealer what do you recomend that they do for an inspection w high miles like this one, can they do a compression test, or is that to involved? I know they can run diagnostics on the injectors and other systems because Ive done that before. What about any tranny tests? Thank you for all your help and sorry for the new guy questions...
Madvan is pretty up to speed on the tranny and what to look for but the checks that I would do is drive it until it warms up, then put it through its paces, slow accelleration, normal accelleration, WOT (wide open throttle) acceleration make sure that every thing shifts normal, then while pressing on the brake firmly, go to wide open throttle, and see how high your rpms get, this should only take about 1-2 seconds long enough for the engine to max out and you get an rpm reading. Madvan posted the RPM that you should read, and that will tell you the condition of the Torque converter. I will see if I can find the post.
Originally Posted by 2 stroke man
how do i test stall?
Originally Posted by c00nhunterjoe
powerbrake it to the max without spinning the tires
thats what i thought. right now its low cause my rear axle seal is leaking on my brakes lol. but, normally its around 3000 best i recall. i stage it up to race lol
Originally Posted by MADVAN
3000 RPM
Bill
Bill
Originally Posted by bkcowboss
Hey bill what should you see with the stall check??
Stock TC should be 1900 to 2200 Max.
Bill
Bill
if you want to see the thread here it is (push me)
Cool thanks bkcowboss, I'm tryin to break it down now....TC lock should b 1900-2200 or 3000? Wouldnt it depend on 3.55 or 4.10s, open or LS and how big a rubber u were runnin as to when she would start to spin? My last truck was a shiftin son-a-tha-bitch but w 36's and 3.55s she wouldnt power brake inless you were in 4Lo with the hubs unlocked. This truck im lookin at has 4.10 open and 35's.
i keep pushing the link but nothing happens..........
everything posted is good, also check the tranny for shudder on hard accel from a standstill.
check the turbo fins for dirt ingestion.
see how the engine strats dead cold
ask why the truck was at an auction
how many miles on the rebuilt tranny?
who rebuilt it?
warrenty?
for an overall engne check you can scan for codes, do an inector buzz test and a cylinder contribution test with a scanner for anything major to pop up.
who rebuilt it?
warrenty?
Here they are, the white is my old one and the red is the one i'm looking at...By the was dose any recognise the red one, it was a one owner Texas truck. https://www.ford-trucks.com/user_gal...id=178117&.jpg
