4WD snappin' & poppin"
Greetings all,
Been a while since I logged in but you know how the Marines are...always movin...glad to be back. Anyways, just the other day after it had snowed here in the mountains, I attempted to use my 4WD in my 2005 Screw, and I don't know whether or not it's because I was on an incline but I heard it engage. When I started to go in reverse, I heard some snappin' and poppin' sounds coming from what sounded to be the transfer case, and as soon as I let off of the gas it felt like someone hit me from the rear pretty hard. Today, I put it on level ground and found the transfer case fluid was low, so I filled it, and took it out to test it. The 4WD engaged just fine, but as I accelerated with my window down, I could still hear the snappin' and poppin' sounds...now that's in 4L and 4H. Is this normal, or should I be looking into something else? Any suggestions would be greatly appreciated.
Thanks,
Joe
Thanks,
Joe
Thanks for the responses. The sound the first time when I was trying to back up a hill in the snow was quite loud...it happened as I was letting off of the gas, and as I said before, it felt as if someone was hitting me from the rear. The more gas I gave it the harder the hit. But, yesterday I engaged the 4WD, and I only heard noise coming from what sounded like the transfer case and it wasn't very loud, just a poppin' sound as I started to accelerate and move forward.
