Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-17-2008, 05:52 PM
popbreed is starting off with a positive reputation.
Dwell changes as vacuum advance works
I have been chasing a miss in my 292 64f100 for several months. Miss occurs at speeds above 30 mph and is not constant. I checked over the distributor (rebuilt about 10,000 miles ago). Changed points (US made), changed the ground wire to a standard one (rebuilder had installed a heavier wire which made it not as flexible). Did not help. Rebuilt the carb because I noted the miss stops if you acclerate so I assumed this was because of the power valve opening and therefore I had a problem with the intermediate circuit. No help. Today I rechecked the ignition again and found the dwell decreased approx. 5 degrees as rpm's increased. Disconnectced and plugged the vacuum advance line and the dwell drop stopped. I now have the vacuum line caped and will test the PU on the road to see if that cures it. Question is, what would cause the dwell to drop as vacuum advance comes in? It would appear to me the rubbing block on the points is in the wrong position relative to the cam lobes. Theortically, as the breaker plate is rotated by the vacuum advance, the distance between the rubbing block and the cam surface must not chnage. Am I all wet? Anybody else seen this condition? Thanks for the help
POP
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-01-2008, 07:26 AM
Walston's Avatar
Walston is gaining momentum as a positive member of FTE.
The dwell change seems normal to me. Have you set the timing with the engine warm and the vacuum advance plugged? Frankly it sounds to me like you have a bad plug wire or cracked distributor cap. You may try looking at the engine running in the dark. Race the engine and see if you have something sparking?
__________________
Walston and Son
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
