Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-17-2008, 12:29 PM
Bill W's Avatar
<<< My Truck
Bill W is a splendid one to beholdBill W is a splendid one to beholdBill W is a splendid one to beholdBill W is a splendid one to beholdBill W is a splendid one to beholdBill W is a splendid one to beholdBill W is a splendid one to behold
Timming?
Hey all, I need some help with timming my 390 fe block It wants to run way addvanced? thats were it sounds the best at idle. I set it by ear and when we put a light to it, It was 30 + deg. We set it at about 14 and now I get a lot of backfire on the slow down OK the dist is a aftermarket Mallory Mecanical addvance unlite with a Protronix insert for electronic Ign also has Offenhauser intake, edelbrock carb 600 cfm Sorry dont know the internals of the engine
but it has a lope to it, cam? My Question is what is a good place to start? as far as numbers for timming, Can someone Help if you have Knowlage about this Stuff, Cause I'm lost??? Thanks
__________________
Praise the Lord and pass the ammunition!
My Truck- Here!
Join AZ Chapter Here!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-17-2008, 02:00 PM
ubereal2's Avatar
ubereal2 is starting off with a positive reputation.
Bill what year, make and modle? Is i the 95 F150?
Bob
  #3 (permalink)
Old 02-17-2008, 07:12 PM
Bill W's Avatar
<<< My Truck
Duh! Sorry I cant belive I did not say. It is a 66 F100 Custom Cab motor is from a Galaxy same year
__________________
My Truck- Here!
  #4 (permalink)
Old 02-21-2008, 06:49 PM
ubereal2's Avatar
I ran downstairs and had a beer and remembered why "I went downstairs"... I have a Chilton's from the 60's.
According to it you're timing should be at 10 degrees, before top dead center.
Bob
  #5 (permalink)
Old 02-21-2008, 07:45 PM
Bill W's Avatar
<<< My Truck
Very hard starting at that setting, Would a aftermarket Cam and the high performance stuff, effect the timming? Cranks a long time before starting after warm up. I dont know much about HP stuff, let alone what the factory setting would be Thanks I will try 10 Btdc again and drive it for a while.
__________________
My Truck- Here!
  #6 (permalink)
Old 02-21-2008, 10:18 PM
ubereal2's Avatar
I would think that an aftermarket cam would effect the factory timing. Was the complete engine built? Does it have a new timing chain and gears?
Bob
  #7 (permalink)
Old 02-21-2008, 10:53 PM
Bill W's Avatar
<<< My Truck
Dont Know? I was thinking that the Mecanical addvance on the Dist would make some differance? The backfire through the carb on the slow down tell you anything, or the hard start when warmed up? I dont know wich way to go with it.
__________________
My Truck- Here!
  #8 (permalink)
Old 02-21-2008, 11:00 PM
ubereal2's Avatar
The backfiring thru the carb, and hard to start when warm, sound like a timing issue for sure.
  #9 (permalink)
Old 02-22-2008, 10:46 AM
Mike G is starting off with a positive reputation.
Hey Bill, why have you started having problems? Did you recently remove the distributor? You did not state that it was running fine and now you have issues. Just looking for some history.
--Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
  #10 (permalink)
Old 02-22-2008, 11:05 AM
Bill W's Avatar
<<< My Truck
Hi Mike, Thanks. Well it was a truck I bought for my son, I'm glad he cant drive a stick Shift lol, Crashed in the front and now back together. Been driving it for a few weeks now. OK so it had the Mallory unilite stuff in the dist giving me problems with the wires to the crane fireball box, Soooo.... I replaced the insides with Protronix insert but doing all of this I had the Dist out once to take it to Don's Hot Rod shop They have a tester. I'm not to Knowlageable about this kinda thing, so need some help I set it by ear and when we hooked up the timming light it was 38 deg btdc
we set it at 14 and now just trying to get it closer so it will start easy when warmed up. The truck sat for 3 years before I got it to where it is now.
__________________
My Truck- Here!
  #11 (permalink)
Old 02-22-2008, 02:54 PM
Reason I asked... You may have gotten that dist in at 180 degrees off. The steps I would take would be to get the motor at TDC on the compression stroke, then reset your dist to the #1 plug. Also check the wires and make sure they are routed correctly and making good contact.
--Mike
__________________
Mike G
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
  #12 (permalink)
Old 02-22-2008, 04:49 PM
chrono4's Avatar
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
An engine wont run at 180* off, so thats out. It may sputter, but no vroom. What kind of balancer does it have on it? If it runs best at 30*, leave it. What may have happened is the outside of the balancer can rotate some over time, which will throw your marks off. You could bring the #1 up to exact tdc, and mark your balancer to see if its off. If it is, then just use an angle finder to mark out 10*, and time to that.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
  #13 (permalink)
Old 02-22-2008, 08:52 PM
Bill W's Avatar
<<< My Truck
Hummmm, I changed the Balancer also? Very good Advice Andrew, I will find TDC and check the marks, I will post the results when I get that done. Now can someone tell me which side the #1 cyl is on?
__________________
My Truck- Here!
  #14 (permalink)
Old 02-22-2008, 09:02 PM
chrono4's Avatar
not entirely sure, but the intake manifold should be marked for each cylinder
__________________
--Andrew--
Welding a 9"
Technical Advisor
  #15 (permalink)
Old 02-22-2008, 09:06 PM
Bill W's Avatar
<<< My Truck
Aftermarket intake Offy 360 Deg. so no markings, I should know cause I hooked the timming lead to it. Lol Just making sure!
__________________
My Truck- Here!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
