#1 on fords(w/ a few exceptions) is the right front or rather the passenger side front
So it starts hard at about 10degrees BTDC but much better at 30degrees BTDC, or did I miss understand you and have it backwards that it just runs better at 30+ degrees, usually when it starts hard it's advanced to much, but maybe I'm mixed up here, when does it start hard? Next question, are you sure you were on the #1 sparkplug wire w/ the timing light since you asked?
__________________
Redneck-Cowboy
86 F-150 4x4, 4spd w/ a 300, Headers, 500 cfm 4-barrel, D.U.I or "H.E.I" ignition/dist., mild cam with chevy rockers, steel timing gears, decked the block and head .015, bored .060, true dual straight 2.5" all the way back ( a little to snappy, but frickin LOUD)
