Join Our Site - Its free, quick and easy!
Click Here to join.
02-17-2008, 02:18 AM
New Windsor, old GT40
I'm buying a set of 70s GT40 heads. How well will the match up to my 89 351 EFI block? I know of course I'd have to get injector holes bored.
__________________
91 F-150 302 Nite 4x4 Ext Cab 312,000 miles
In junk Yard... RIP baby.
89 F-150 Lariat 4x4 Std Cab Long Bed 125,000 miles on a 351 C6 3.55 posi
Blew a head gasket the other week, beginning total overhaul on everything.
Sponsored Links
To remove this ad, register today!
02-17-2008, 12:18 PM
Quote:
I didn't think the GT40 heads existed before the '90's, and if this is what you are getting they will fit just fine. If these are off a 5.0 then the bolt holes will have to be drilled out to 1/2". Post the casting numbers if you have them.
The injectors go in the intake, not the heads.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
02-17-2008, 04:20 PM
Nevermind... They are plain jane D00E
EDIT: It what I get for playing the telephone game with autoparts...
Are these any good to have built up?
__________________
02-20-2008, 04:34 PM
they are a pretty decent choice. probably about 3rd best choice behind GT40P and GT40 heads as far as factory iron go.
has larger valves (1.84 intake) and larger ports than 302 and later 351 heads and slightly smaller chamber, 60 or 64 cc if not mistaken.
a little port work (especially on exhaust side) and a good 3 angle valve job and will be pretty decent heads for a street engine.
the injector holes are in the manifold, not the heads. unless you mean for the smog pump.
rgds
Mike
02-23-2008, 12:26 AM
I have some documentation that lists the 351w's at 60cc. I agree, they are pretty decent heads.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
