Need Info On Installing Stacks Please
Ive got a 5 inch stack kit from Grand Rock thats been sitting here for about a month just waiting to go on the truck. The reason i havnt started putting it on is because im not sure about figuring out where to place the T pipe and cut the hole...how did you guys with stacks figure out the placement of your T pipe? Any other tips you can give on installing the stacks would be great too...Thanks
i would set the T-Pipe in the bed where your going to want it keeping in mind how far back its going to need to be and make sure the shorter end of the T is on the passenger side. get everything plumbed from the bottom to make sure you have the T set far enough back and use the T to mark a hole from the top and cut it there. i'm not very good at explaining stuff, but i hope this helps.
Originally Posted by FARM69
The best way to do it would start plumming it up from the downpipe to the bed. This will give you an idea as to where the hole should be.
