Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-17-2008, 12:02 AM
BigJake86 is starting off with a positive reputation.
Unhappy 1992 F350 Supercab 2wd 7.3 towing capacity?
Hey guys, I hate to post a generic topic like this but I simply can't find a solid answer. I have a 1992 F-350 2wd SuperCab dually, new 7.3 diesel, 5-speed with
4.10 gears. I need to know the towing capacity (ie. gooseneck/tag-along). I don't know the weight of the truck and therefore I'm not sure how much I'm supposed to be able to haul. If anyone has a booklet from '92 that would be great. Thanks, Jacob
PS I'm looking at getting those fancy air bags so I can compete with Dave S.
__________________
2001 Excursion Limited 4x4 7.3 DP Tuner & F5 23MPG
1999 F-250 SuperCab 2wd 7.3 6-speed STOLEN!!!
1993 F-350 2wd Dually 7.3
1986 F-250 2wd 6.9
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-17-2008, 02:55 AM
Dieselguy89 is starting off with a positive reputation.
This is the Manual Transmission part from my 92 owners manual if this is wat ur looking for
  #3 (permalink)
Old 02-17-2008, 05:50 AM
PLC7.3 is gaining momentum as a positive member of FTE.
This is right from the Ford Recreational vehicle and trailer towing guide 1992-3....
The GCWR of the Fseries trucks towing a frame hitched trailer.
F series with 7.3 and automatic is:
355....12000lbs
410....17000lbs
F series with 7.3 and manual is:
355....12000lbs
410....14000lbs
The CGWR of the Fseries trucks towing a Fifth wheel trailer.
F series with 7.3 automatic is:
355....12000lbs
410....17000lbs
513....18000lbs
Fseries with 7.3 and manual is:
355....12000lbs
410....14000lbs
513....17000lbs
As you can see trans makes a difference, these numbers were considered low at the time our trucks were sold new. I think Ford was just doing CYA.....
__________________
93 F250 SC 4x4 E4OD 355LS
  #4 (permalink)
Old 02-17-2008, 08:18 AM
Darrell Maryland is starting off with a positive reputation.
I have a 92 f450 superduty 7.3 where can i find what gears i have .
  #5 (permalink)
Old 02-17-2008, 03:55 PM
Excellent information guys! Thanks for your input!
__________________
1986 F-250 2wd 6.9
  #6 (permalink)
Old 02-17-2008, 07:51 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Darrell,
What RPM are you running at what speed with what size tires and which tranny do you have?
2030 RPM
60 MPH
235/85-16 tires
ZF 5
As an example would work out to 4.10 gears
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #7 (permalink)
Old 02-17-2008, 09:23 PM
optikal illushun's Avatar
optikal illushun is starting off with a positive reputation.
why was the gasser rated for so much more?
__________________
93 F150 XLT 4x4
Modded 300/Built E4OD
RC 2 1/2" lift
33 ProComp MTs
15x8 AR 147's
Crane 503905 cam
Crane coil
Taylor wires
Hedmen headers
1988 F350 Custom 4x4
7.3 IDI/ZF
RayWel lid w/ Opti'ized ram air
"G" codes
True 2 1/4" duals w/ packs
315/75/16 ProComp Xtreme ATs
16x8 White waggies
Alpine/Infinity stereo
3G soon
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
