Truck acting strange in 4X4
Old 02-14-2008, 01:02 PM
MyFX-4's Avatar
MyFX-4
MyFX-4 is offline
I noticed during a snow storm last night that when I was in 4 hi, if I either was turning or backing up, my truck acted like the emergency brake was on, felt like it was in the front end, it is a 2004 FX-4 Any ideas or is this normal ?
Old 02-14-2008, 01:22 PM
Twinsdad98's Avatar
Twinsdad98
Twinsdad98 is offline
THat's normal. Even though it was snowing, was the road slippery? If the one wheel can't slip relative to the other wheel, you will get some binding. Not an issue as long as you don't do it all the time.
Old 02-14-2008, 01:46 PM
MyFX-4's Avatar
MyFX-4
MyFX-4 is offline
What is doing it, the posi in the rear ? It was a little slick out, I've had trucks in the past with posi in the rear and never had one act like this !
Old 02-15-2008, 07:10 AM
jmizell49's Avatar
jmizell49
jmizell49 is offline
I had the same problem. Took if off-road in the dirt and everything works fine.
Old 02-15-2008, 08:16 AM
dfishrmn88's Avatar
dfishrmn88
dfishrmn88 is offline
Twinsdad98 is right. The cause is in the front end, not the rear. It is really noticeable on dry pavement which is discouraged due to that binding. If it goes away when you straigten out, that most likely is the cause.
Old 02-16-2008, 09:40 PM
MyFX-4's Avatar
MyFX-4
MyFX-4 is offline
It doesn't do it on dry pavement, or in 2 wheel drive, what would be doing it ?
