Join Our Site - Its free, quick and easy!
Click Here to join.
02-16-2008, 08:34 PM
Ds 2150
can i use a 2150 carb with a duraspark setup?
Sponsored Links
To remove this ad, register today!
02-17-2008, 08:23 AM
yup,you can use it for whatever you want
02-21-2008, 02:52 PM
I have a bunch of vacuum ports on the carb and on the base of carb should i plug the or leave them open with my DS conversion.
02-22-2008, 12:25 AM
lets start from the beginning,what are we dealing with???? what engine,what rig
02-22-2008, 03:59 PM
02-23-2008, 12:23 AM
this might help
02-24-2008, 10:11 AM
i heve converted to DS and removed all the vac bank but i am left with many open vac ports on the carb and cab spacer shuold i plug the or leave them open
bronco 2 2.8l 1985
02-24-2008, 10:13 AM
02-25-2008, 11:30 AM
02-25-2008, 11:38 AM
there is a screw with a spring on my car is below the fuel filter on my BII. what is this screw for ? how you use it?
02-25-2008, 12:19 PM
there should be 2 of them. there the idle mixture screws
02-25-2008, 12:26 PM
02-26-2008, 07:27 PM
absolute correct. how do i adjust them? my exhaust is super rich.
02-27-2008, 01:47 AM
for a starting point,screw them in till snug,back them out 2 turns, then one at a time screw them in till the engine starts running rough,them back them out till the engine smooths out or the highest rpm
02-27-2008, 08:13 PM
would that take care of the super rich exhaust?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
