Quote:
Originally Posted by scottie2hottie
I've used the drill and hex bit trick to prime plenty of times, but never on a motor that doesn't have a distributor. In fact, I've never had a need to prime a motor that didn't have a distributor, YET. I'm sure time will run out for us old fashioned folks. How do you access the pump drive with the pump installed?.....about being LSU boy, guess I can't really trump you, cuz you trumped us pretty bad last month didn't ya LOL.
Scottie,read my above post again about "bench" bleeding a master cylinder.The theory is the same for the oil pump;"bench" prime it,as he said he did.And,you see another person knows about the "vaseline" trick! Stick around;you'll learn something from us old farts!
