PATS Module location? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-16-2008, 05:56 PM
johnpattee johnpattee is offline
johnpattee is starting off with a positive reputation.
The PATS module (Passive Anti Theft System) has failed on my 99 Ranger and I have purchased a replacement module from the dealer. I am unable to locate the module. The diagram from ALLDATA shows it on the passenger side up near the airbag but the diagram from the dealer shows it on the drivers side near the lower kick panel. I have searched both locations and cannot find it (I have the replacement module to compare to).
Does anyone know where this module is located? It is a 4.0L, AT, 4WD, 1999 Ranger Super Cab.
Thanks in advance for any help.
John
Old 02-16-2008, 06:15 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
According to the manual
1. Remove the passenger side air bag module; refer to «Section 501-20B».
µ 2. Remove the passive anti-theft system (PATS) module and bracket.
1 Remove the bolts.
2 Disconnect the electrical connector.
PATS on a Mazda? Pele Ranger & B-Series 2 09-16-2014 10:21 AM
Disable PATS for TS 6-Position Chip BeachEx Excursion - King of SUVs 14 05-21-2014 06:29 AM
Passive anti theft issue (blinking lights) BURNSTOUGHFORD 1987 - 1996 F150 & Larger F-Series Trucks 13 12-03-2009 03:57 PM
SecuriLock (PATS) Theft System Woln't let me Start my Truck Shefferz Electrical Systems/Wiring 2 08-21-2009 05:07 PM
Location of PATS module on 99 Ranger? johnpattee Ranger & B-Series 1 02-16-2008 06:16 PM
Tags
2001, 2003, 99, airbag, anti, f150, ford, location, module, passenger, pats, ranger, replace, side, theft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
