more 9" meaurement geekism
Originally Posted by 52 Pickup
I don't remember the measurements cause I did the swap about 18 or 19 years ago. I snagged a 9" from a 68 F100 (long bed) to replace my 52 F1's rear and it bolted right in. The width was the same. The perches were even the same width but I did have to cut them loose and adjust the pinion angle and make shock mounts because I couldn't use the 52 hardware on the larger axle tubes. I later discovered I got 31 spline axles too.
Rick
Rick
I have been told you just need to shim the spring perches to achieve the correct pinion angle. How far off was yours? I have been asking around, here and other people I have run into, to get the skinny on how's it done. I keep getting slightly different stories. Some say it's a drop in, others have told me you have to replace the spring perches and modify the drive shaft, and everyting between. I get the feeling that either none of the early F-1s were made exactly the same or each pre-'73 9" is slightly different.
I will be swapping my rear axle this spring sometime, if we ever stop getting snow! I also have read that you can use the shock mounts from a F-2, that the 9" axle has the same diameter. I have a F-2 parts truck sitting in the back forty.
Havi,
There is alot of room under those phat fenders. I am running old (68 vintage) American Torqe Thrust mags, 8.5X15 (or is that 15X8.5 ?) with 255/60's on them and still have plenty of clearance, inside and out. My son has 275/60 15's on his 52 with plenty of room left. With the correct offset I believe a 10" wide rim is possible.
Later, Rick
Later, Rick
Bob,
The angle was off ALOT. Way too much too shim in my opinion. Probably because it came from a long bed and they have a split driveshaft. I believe if I had one from a short bed the angle may have been closer. The perch centers were the same on both rears but the 68 perches were bigger that the 52. I just cut them loose then loosly bolted them in and rotated the pinion up, tacked them in place then dropped the rear and finish welded. I think I used the same drive shaft from the Dana 44 too. If the pinion angle had been correct it would have ben a bolt in. Not long after that is when I did all of the suspension mods. That is when I put new perches on it to match the new springs. Been running that way for about 18 years now. All the F1 frames should be the same. My friends 48 is just like mine.
Later, Rick
Later, Rick
Bob,
Later, Rick
Later, Rick
As for the '48-52 frames, as far as I know they are all the same with a few minor exception, some of the '52 came with a different engine mounting arrangement to accomodate the new OHV six engine.
I figured that might be the case. The FTE article made it sound like it was pretty much a bolt in:
https://www.ford-trucks.com/article/...ial_Swaps.html
John Niolon has a great page set up detailing the whole pinion aligning procedure and it didn't seem that difficult:
http://www.clubfte.com/users/jniolon...nephasing.html
artscott61
13
04-27-2021 01:10 AM
tractormanbill
22
10-02-2014 02:29 PM
