Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-16-2008, 01:31 PM
wdhille is starting off with a positive reputation.
LUK and Tranny noise
Replaced my Dual mass flywheel with a LUK, and it works fine, but I do hear tranny noise now when starting out. Is this anything to be concerned about? It did not do it with the OEM flywheel.
thanks
Wayne
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-16-2008, 01:43 PM
RLDSL is starting off with a positive reputation.
You can buy a good set of ear plugs,and smile while you appreciate why those factory engineers made the big bucks to come up with the dual mass flywheel setup to cut down on low rpm gear noise and wear
The Luk solid flywheel replacement is a lower cost alternative, but maybey not the best choice.
Some people put heavier oil in, some over fil l to cover the noise up, heavier oil can make it hard to shift.
__________________
'92 F350 CC Dually, 7.3 Ats Turbo, 4" exhaust, Custom Rodney Red aluminum radiator, Zf5, 4.10 ,Western Hauler bed, Air seat, Bilsteins.
  #3 (permalink)
Old 02-16-2008, 02:20 PM
CheaperJeeper's Avatar
CheaperJeeper is starting off with a positive reputation.
Quote:
Yeah, well I'm one of that "some people"...
I put 15W50 Mobil1 synthetic in mine, and I overfilled it - I put 2 gallons in it. Just leave the fill plug in the side and unbolt the shifter assembly, then pour your oil in there in order to be able to overfill it like I did.
If you understand what the real source of the noise is, you'll see why this isn't just "covering up" the noise...
As each cylinder fires the engine produces a large (magnitude) spike of torque for a very short period of time (duration). At low RPMS the amount of time between the spikes is long enough for the gears to have time to move from one end limit of their gear lash to the other. It is this uneven spiking that causes the gear rattle.What it is is the gears rocking back and forth inside from the forward limit of their lash to the rearward limit of their lash.
Heavier oil doesn't just "cover up" the noise - it is thicker which provides more resistance to movement of the gears and slows the movement from one end of each gear's lash to the other end. They move more slowly from one limit to the other, so they don't slam back & forth between their travel limits and rattle. Putting more oil in it means that the gears are staying submerged in oil - to maximize the damping action, rather than just being coated with oil splashed up from the bottom of the tranny.
I chose the 15W50 because at colder temps it will have about the same viscosity as 15 weight - which is about the same thickness as the ATF that originally comes in the ZF-5. BUT when hot the oil has the viscosity of 50 weight - which is significantly thicker than ATF (or 15 weight) would be when at the same temp (hot). Of course hot 50 weight oil may still be thinner than cold 15 weight - though it won't be nearly as thin as hot 15 weight would. That is the beauty of multi-vis oil. Bottom line, with 15W50 in it mine is not hard to shift when the temp is below freezing OR when it's over 100 outside.
Last thing about the oil - the plate on the side says to use synthetic ATF, so I chose Mobil 1 synthetic because 1) it is synthetic like Ford recommends, 2) it was the only 15W50 I could find at the time, 3) being synthetic it will last a LOT longer than dino juice without breaking down - getting dark, and burned, and loosing its lubricity - even when exposed to heat & pressure.
One other thing you can do to decrease the gear rollove noise, is to increase your timing a bit. I upped mine from the stock 625 +/- 50 RPMs to 750/800 RPMs. This shortens the time period between cylinders firing making the torque spikes closer together. If they aren't far enough apart for the gear to move from one end of it's lash range to the other end then the rattling noise decreases...
Good luck with it.....
__________________
1986 F250 Super Cab 4x6 (dually), 6.9 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
SOLD! 1986 F250 Super Cab 2WD, 6.9 NA, C6 Auto, 3.55 gears, K&N, dual RAM-air, custom Y-pipe to 3" ATS exhaust. 120k? 220k? Dunno’ but still running strong when she left...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
