Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-16-2008, 01:12 PM
35w 35w is offline
35w is starting off with a positive reputation.
Wiring auxillary b/u lights
I have an 06 F250 CC FX4 6.0 and want to install fog lights as extra lighting when in reverse and rear lighting with a switch when in Park. I have the upfitter switches and can use one for this. What is the best way to do this so all connections are water/moisture tight and look professional?
Thanks for you help
35w
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-16-2008, 03:45 PM
NJF350SD's Avatar
NJF350SD is gaining momentum as a positive member of FTE.NJF350SD is gaining momentum as a positive member of FTE.
You are looking at a relatively complex wiring project. You are looking at 2 seperate circuits (Regular BU circuit, plus a second for the manual switch you want). You will also need to include a diode in the manual curcuit so that you don't feed voltage/current back though your back-up light circuit when you turn your manual switch on.
Personally, I bought a set of standard work lights from a towing supply company (AW Direct) mounted them onto the bottom of my bumper at the corners with stainless hardware using the OEM holes and tied them into the reverse wiring circuit from the trailer wiring harness.
If you wanted something additional, you can get a set of "stealth lights" which mount around your receiver hitch and tie them into a seperate switch in the cab for use when stationary. Just my $.02.
Cm
__________________
Chris
2008 F350SD CC PSD Short Bed
2000 F350SD CC PSD Dually - Sold
1995 F350 CC PSD Long Bed - Traded-In
1987 F250 STD Cab - Gasser - Sold
  #3 (permalink)
Old 02-18-2008, 09:53 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
For a professional look, get a soldering iron and some shrinkwrap tubing. Slide the shrinkwrap over the wire, solder the wire, and then slide the shrinkwrap over the joint and heat it.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 02-18-2008, 08:47 PM
35w 35w is offline
Thanks guys I appreciate the help.
35w
  #5 (permalink)
Old 02-21-2008, 02:49 PM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
Wiring the lights so they hook up with a 2 wire trailer(trolling motor) connector and
having a 30 foot extension wire and a quick release mount(Cclamp, magnet) for the light will give you the ability to use the light under the hood, back on the trailer for changing a tire etc., or when
you just need some light somewhere. I use a halogen fog light and it is bright as heck
and will make someone tailgating you back off.
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #6 (permalink)
Old 03-02-2008, 01:24 PM
rotun's Avatar
rotun is starting off with a positive reputation.
Use a relay, tap into the reverse light wire to activate the relay. You'll have to run a seperate power feed from the upfitter to power the relay and then jump the relay straight to the lights from the upfitter as well, which you can run in a plastic wire loom. You'll want to wire it so you have the ability to turn them off when in reverse as they are not legal (just in case law enf. is behind you). Also, as stated above.....solder and shrink wrap will never let you down. This way you can turn them on with the upfitter while in park, they will come on automatically in reverse but only as long as the upfitter is on.
__________________
'07 f-350 CC LB Harley
SoCal FTE
Join our Chapter *HERE*
  #7 (permalink)
Old 03-03-2008, 10:21 PM
cangim's Avatar
cangim is gaining momentum as a positive member of FTE.
When I did mine I went the hard way first, then once I was done came up with his idea. Set your lights to work with the center pin on the 7way RV plug at the back. This is a fuse 20A circuit that will come on when you place it in reverse. Then tie your upfitter switch into the BU/AUX relay in the fuse box. You will need to use a couple of diodes to eliminate any feed back. I haven't check for sure but fairly positive all the relays are controlled by supplying the 12V and not sinking or grounding them to activate. To check remove the relay and test for continuity between ground on both of the coil contacts. Which ever one has continuity is the ground side. Then for sanity I'd check the positive, turn the key on but don't start it, set the park brake, and place it in reverse. The second coil contact should have 12V or so present. This is the wire to connect into.
__________________
Wishin I was still camping somewhere....
-Mike
  #8 (permalink)
Old 03-05-2008, 02:25 PM
ron's power stroke's Avatar
FORD the rock crusher
ron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to behold
Quote:
Thanks for you help
35w
this can be done and works quite well...i did it to my truck and i love it..
http://www.ford-trucks.com/forums/59...with-pics.html
__________________
Early 99 7.3 F350 auto,AFE stage2 5" strait pipe. DP tuner ,140 IDM,Modified 17* HPOP..DI RR
Ryan Casserly's SS stage 2's moded 100% over nozzles
exploded view of a 7,3
Reconstructed 7point3.com
  #9 (permalink)
Old 03-06-2008, 10:04 PM
35w 35w is offline
Thanks Ron PS. I remember that thread thanks for the link. I saved it to my desktop.
35w
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
