Rear Brake Caliper Torque Specs
Just torqued off my caliper slide bolt. Have looked everywhere but can't seem to find torque specs for caliper mounting bolts, or caliper slide bolts for REAR brake of 2004 F250, 4wd, srw. Anyone with any info, I would greatly appreciate it. Need to get rig going in morning. Thaanks again all.
Chad
Chad
Remove the 2 brake caliper anchor plate bolts and the brake caliper anchor plate.
To install (F-250, F-350 single rear wheel caliper), tighten to 275 Nm (203 lb-ft).
To install (F-350 dual rear wheel caliper), tighten to 275 Nm (203 lb-ft).
To install (F-450, F-550 dual rear wheel caliper), tighten to 400 Nm (295 lb-ft).
2 brake caliper bolts and position the caliper aside.
Support the caliper using mechanic's wire.
To install (F-250, F-350 single rear wheel caliper), tighten to 35 Nm (26 lb-ft).
To install (F-350 dual rear wheel caliper), tighten to 76 Nm (56 lb-ft).
To install (F-450, F-550 dual rear wheel caliper), tighten to 62 Nm (46 lb-ft).
I am still looking.....I think the 200lb-ft sounds like a bit much but hope some of this helps.
