I used to do burnouts in my 64 all the time. Very torquey engines. I did tons of burn outs with the stock 3.50 gears. Then I put a locker and 3.73 gears in it. After a 4 barrell holly and reds headers with duel exhaust It would smoke the tires at will under about 15 MPH. Crappy tires help too!
Burnouts arent that hard on the engine if you are not reving it sky high. It doesn't create a lot of load just spinning the tires. Launching the truck with traction is much much harder on the drive train.
If you do a 3000 rpm burn out for a few seconds it has less load on the engine that accellerating at the same RPM. The engine does not have the resistance of pushing a 4k pound brick through the air. It's just spinning tires with no load on it. Now the tires don't like it much but its tons of fun.
That engine I used to beat on finally let go cruising down the interstate at 65 MPH because of lack of oil to the top end.
SO Burn out my friend and live life without fear. For someday you will have to rebuild your engine anyway. Then you can make it badder and do better burnouts!
MIke
__________________
64 F100- just parts now.
65 f100- DD and hot rod
88 Jeep grand wagoneer.
82 Kawasaki KZ1100
