Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-15-2008, 08:08 PM
52 F3's Avatar
52 F3 52 F3 is offline
Garage is empty, add now
52 F3 is starting off with a positive reputation.
Valve spring removal
I need to know if valve springs can be removed without taking the head off. I have a couple valves that seem to have week springs and would like to try to change them without pulling the head. The intake would be an easy R&R.
This is an 8RT in a 52 F3.
Thanks Richard
  #2 (permalink)
Old 02-15-2008, 09:14 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
I don't think you don't have room to maneuver the springs under the valve stem even if you pushed them up as far as they'd go with the lifter at the bottom.
  #3 (permalink)
Old 02-15-2008, 10:18 PM
Quote:
Originally Posted by mtflat
I don't think you have room to maneuver the springs under the valve stem even if you pushed them up as far as they'd go with the lifter at the bottom.
found after time expired - boy that sounded stupid!
  #4 (permalink)
Old 02-16-2008, 07:20 AM
52 F3's Avatar
Thanks for the reply.
That is kind of what I thought but asn't sure how much room there would be to raise the valves. I guess I will pull the intake anyway and see if I can clean and lube up the stems and work them around enough to get them to stop sticking and if not pull the heads.
Sure crowded working under the hood of this thing.
Richard
Tags
2004, 390, explorer, ford, removal, remove, spring, springs, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
