Trailer wiring diagram - Ford Truck Enthusiasts Forums
Old 02-15-2008, 07:12 PM
straightsixer straightsixer is offline
straightsixer is starting off with a positive reputation.
Is there a source for diagram and wire colors for hooking up a round 6-prong plug, other then my Haynes manual??? There are two round empty male plugs with 4 wires going to each one under the left corner of the rear bumper. I put a volt meter on them and one of the plugs appear to be for the blinkers so I know I'm getting warm. These plugs are badly rusted and I will replace them but I'd like a diagram to work off of.
Thanks
Old 02-15-2008, 07:21 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Do a search in this Forum...it's been posted a while back.
Old 02-15-2008, 07:40 PM
grafekie grafekie is offline
grafekie is starting off with a positive reputation.
There are SEVERAL standards for the six-pin round plug. That's why most people switch to the seven pin RV plug instead.
Old 02-15-2008, 07:51 PM
Greywolf's Avatar
Greywolf Greywolf is offline
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
BINGO!
no sense re-doing a fine diagram - here is a link:
http://www.accessconnect.com/trailer_wiring_diagram.htm
A problem seems to exist with six-way connectors, because you can pretty much wire them for whatever you want them to do. In other words - the chances of any two of them being wired alike are slim...
Industry standard is the seven-way, or four-way flat.
The five way flat is sometimes used to give an extra wire for auxiliary power, backup lights, or whatever - so you never know what a prior owner of a truck or trailer has done with one of those either without testing the extra wire to discover it's function.
Old 02-17-2008, 08:28 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
As usual Greywolf has provided excellent information with his link. The 2 different wiring options you will see on the 6 way plug will be having the brake wire & 12v power wire reversed. If you hook up to a trailer and the brakes come on, those 2 wires are reversed. This is the only variation on the 6 way plug I have seen, since RT, LT, TM, GD are standard labels.
Old 02-18-2008, 07:48 AM
Greywolf's Avatar
Gotcher back! SEMPER FI...
Old 07-31-2011, 07:56 PM
steve1954 steve1954 is offline
steve1954 is starting off with a positive reputation.
I am using a 7 pin plug on 05 f-250sd and the same on my gooseneck horse trailer. The wiring on the truck was so messed up I gave up on it and took it to a rv dealer and 67.00 later everything works, except, with the 03 2500hd silverado I used to pull the rig with, I also had full time interior lites. Now with the Ford, I have to have the key on to use the interior lites. Talking to other local Ford owners, they also have to do the same. My question is, Do I need to run a separate wire for full time power to the plug? or is there another option, Thanks again
Old 07-31-2011, 08:44 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Put a small deep cycle battery in the trailer. Wire the hot wire from the trailer pigtail to the positive side, and the ground the negative side. The lights will run off of the battery, the truck will charge the battery when it's running.
Old 08-02-2011, 05:44 PM
Thanks for the quick reply, is it posible to tye into the same positive wire from my breakaway battery?
Old 08-02-2011, 05:49 PM
I think it should be possible. I'd have to see how it's wired now though, to really even begin to figure out how to do it.
I've seen stock trailers wired with breakaway batteries that are not hooked up to be charged before, though, and I've never understood why. If there is a good reason, I'm not sure I'd want to mess with it. The best option might be to find a good RV tech nearby and find out how it is and how to fix it up right.
Old 08-02-2011, 05:57 PM
I have a auxillary battery adjacent to the breakaway battery, If I tyed into the + from the truck, would that allow me to charge both batteries and have full time lites as well?
Old 01-31-2015, 11:55 PM
Ace_boy2786 Ace_boy2786 is offline
Ace_boy2786 is starting off with a positive reputation.
I know this is an old topic but, I have a question, is there a battery small enough to mount truck side and connect between truck connector and receptacle to have the constant power on the truck so no matter the trailer you have the constant lights, say your trailer is down (or don't have one) and borrow a buddies who doesn't have the onboard battery.
Old 02-01-2015, 10:59 AM
BPofMD's Avatar
Posting Legend
Wouldn't it be a lot easier just to keep a REAL battery charged and use it that that buddies RV?
Looking for 07 E-450 instrument Cluster wiring diagram Roadster_1927 1999 to 2016 Super Duty 2 11-07-2016 03:58 PM
Installing 08 mirrors on my 2001 McBrider621 Excursion - King of SUVs 7 10-05-2016 10:53 PM
87-91 Round Firewall Plug Pinout RacinNdrummin 1987 - 1996 F150 & Larger F-Series Trucks 7 09-26-2016 07:48 AM
cab wireing bozzo152 1987 - 1996 F150 & Larger F-Series Trucks 1 04-17-2014 04:57 PM
dash wiring on 74 F100 jetfxr74 1973 - 1979 F-100 & Larger F-Series Trucks 17 08-23-2010 07:39 PM
Tags
01, 1995, 97, colors, diagram, diagrams, f150, f250, f350, ford, kiefer, plug, prong, trailer, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
