2008+ 20" OEM Ford F250 wheels - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 02-15-2008, 09:19 AM
Wilson & Co Wilson & Co is offline
Wilson & Co is starting off with a positive reputation.
ANyone see if these have the correct offset to fit the EX?
I am starting to like the look of these and might start looking for a takeoff set
Anyone try them?
Old 02-15-2008, 04:06 PM
NASCAR Mike NASCAR Mike is offline
NASCAR Mike is starting off with a positive reputation.
The rims sit further inward so they will rub your front leaf springs when turning.
Also, by moving the wheels further inward your reduce the stability of the truck. M0oving tires outward increases stability (bigger footprint).
Stay away from spacers ESPECIALLY if you are towing. In stock form, all of the weight of the rims is placed on the hubs, NOT the lugs. If you put spacers you put the load on the lugs and they will fail.
You can get 18" rims from the 2003/2004 Harley Davidson or King Ranch editions. If you want larger you will have to go aftermarket.
Old 02-15-2008, 05:36 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
I thought you could get hub centric spacers...
Old 02-15-2008, 08:18 PM
71-4R3SONS's Avatar
71-4R3SONS 71-4R3SONS is offline
71-4R3SONS has a good reputation on FTE.71-4R3SONS has a good reputation on FTE.
Quote:
Originally Posted by Wilson & Co
Anyone try them?
Yep... Here's a pic:
I just put them on for a test fit... I'll wait until spring to mount them for good weather.
Do a search for "high1" and you'll find loads of info on the topic. I believe he might have been the first to post about running 08 SD 20's on an X.
edit: check out post #11 in this thread...
http://www.ford-trucks.com/forums/66...s-on-05-x.html
Old 02-16-2008, 03:35 PM
thanks for the info!!
Old 02-18-2008, 07:33 AM
Hub centric spacers will run you about $150 each. Now add $600 to you tire and rim price.
Cheapest I have ever seen 20" rims with tires are $1600. $2200 for rims & tires - YIKES!
Even with the spacers be prepared for increased bearing wear as you are now increasing the moment arm on the bearings thus more pressure.
Old 02-18-2008, 10:35 AM
yep...thought about that and will not pursue
Old 02-18-2008, 02:37 PM
Monsta's Avatar
Increased bearing wear is a stretch. I can see if the wheels have a huge positive offset and stick out way past the fender wells. But the OEM 20's (et al) will still be centered underneath the hub with the spacers and will exert minimal additional leverage on the bearings.
Steering stabilizers bizzelj 6.0L Power Stroke Diesel 4 07-12-2015 11:48 AM
HOUSTON AREA TRUCK CLUB plumber01 Texas Chapter 78 06-23-2013 11:22 AM
lifted 06 expedition eddie bauer (anyone else) jrosstruckin Expedition & Navigator 4 08-23-2011 11:44 AM
No Heat from Defrost and Heater Mike-11 Expedition & Navigator 4 11-03-2010 12:19 AM
Motorcraft 4180...Dashpot.. ozark1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 09-21-2010 02:56 PM
Tags
08, 18, 20, 2008, excursion, f150, f250, ford, oem, rims, sale, stock, truck, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
